Problem with "Displaying posts and topics on external pages"
Postby powerbonger » Thu Jan 20, 2011 8:06 am
Hi! Total newbie to PHP and MySQL here. A couple of days ago I ran across battye's tutorial on how to display PHPBB3 posts and topics on external pages, found here: http://wiki.phpbb.com/display/MODDOCS/Practical.Displaying+posts+and+topics+on+external+pages
I followed the instructions to the best of my ability (er...copy paste :D ), created a home.php and external_body.html, and went with the code for Example 3, but I kept getting this error:
General Error
SQL ERROR [ mysql4 ]
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'AND t.topic_status <> 2 AND t.topic_approved = 1 ORDER BY ' at line 2 [1064]
An SQL error occurred while fetching this page. Please contact the Board Administrator if this problem persists.
Here is the code I used for home.php (copy-paste goodness):
* home.php
* September 29, 2009
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './phpBB3/';
// Start session management
$user->session_begin();
$auth->acl($user->data);
$user->setup('viewforum');
* posts and topics */
global $db, $auth;
        switch($type)
            case 'forum':
                $type = 'forum_id';
                break;
            case 'topic':
                $type = 'topic_id';
                break;
            default:
    // no restrictions
    $out_where = '';
    if( $size_gen_id > 0 )
        if( $type == 'topic_id' )
            $sql     = 'SELECT topic_id FROM ' . TOPICS_TABLE . '
                        WHERE ' .  $db->sql_in_set('topic_id', $gen_id) . '
                        AND ' .  $db->sql_in_set('forum_id', $auth_f_read);
            $result  = $db->sql_query($sql);
            unset($gen_id);
            $gen_id = $topic_id_list;
    $j = 0;
        $j++;
    return $out_where;
$search_limit = 5;
$forum_id = array(2, 5);
$topic_id = array(20, 50);
$posts_ary = array(
     'SELECT'    => 'p.*, t.*, u.username, u.user_colour',
     'FROM'      => array(
         POSTS_TABLE     => 'p',
     'LEFT_JOIN' => array(
         array(
             'FROM'  => array(USERS_TABLE => 'u'),
             'ON'    => 'u.user_id = p.poster_id'
         array(
             'FROM'  => array(TOPICS_TABLE => 't'),
             'ON'    => 'p.topic_id = t.topic_id'
     'WHERE'     =>  str_replace( array('WHERE ', 'topic_id'), array('', 't.topic_id'), $topic_id_where) . '
                     AND t.topic_approved = 1',
     'ORDER_BY'  => 'p.post_id DESC',
      $topic_title       = $posts_row['topic_title'];
      $post_author       = get_username_string('full', $posts_row['poster_id'], $posts_row['username'], $posts_row['user_colour']);
      $post_date          = $user->format_date($posts_row['post_time']);
      $post_link       = append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . $posts_row['forum_id'] . '&amp;t=' . $posts_row['topic_id'] . '&amp;p=' . $posts_row['post_id']) . '#p' . $posts_row['post_id'];
      'TOPIC_TITLE'       => censor_text($topic_title),
      'POST_AUTHOR'       => $post_author,
      'POST_DATE'       => $post_date,
      'POST_LINK'       => $post_link,
      'POST_TEXT'         => censor_text($post_text),
    page_header('External page');
        'body' => 'external_body.html'
    page_footer();
And, just in case, here is the code for my external_body.html (which is located in the \prosilver\template\ folder of my phpbb3 directory:
<!-- BEGIN announcements -->
Title: {announcements.TOPIC_TITLE}<br />
Post author: {announcements.TOPIC_AUTHOR}<br />
Post date: {announcements.POST_DATE}<br />
Last post text: {announcements.POST_TEXT}<br />
Post link: {announcements.POST_LINK}
<!-- END announcements -->
Can anyone show me where I went wrong? I'm still new to this, and would greatly appreciate any help. :)
Regards,
powerbonger
powerbonger
Re: Problem with "Displaying posts and topics on external pa
Postby powerbonger » Thu Jan 20, 2011 8:09 am
Oh, to add, when I tried to use the code for Example 4 on the same file above (replaced the code from Example 3), it worked as intended, and the error didn't show up. :?
powerbonger
Postby battye » Thu Jan 20, 2011 1:40 pm
Hmm, that is strange. I tested all of the examples before I published any of them online, and I'm not immediately seeing what the problem could be.
Could you try removing this line:
And letting me know if you still get the SQL error?
Welcome to the forum powerbonger, feel free to check out OT Forum if you haven't already had the chance :)
Postby vaalsh » Fri Aug 12, 2011 8:31 am
Hi!
Script works fine on a separate page, but when i am trying to put it (include "home.php") on main page
of my site, I am getting error:
<< in file /includes/functions.php on line 4284: Cannot modify header information - headers already sent by (output started at index_test.html:6) >>
Any help greatly appreciated!
vaalsh
Postby battye » Sat Aug 13, 2011 4:26 pm
Can you please post the first 10 lines of index_test.html?
Return to Web Design
Who is online
Users browsing this forum: No registered users and 2 guests
cron
