Event Calendar RSVP
Re: Event Calendar RSVP
Postby battye » Sun Mar 21, 2010 9:58 am
I'm really sorry havocwreaker, I've had a really busy fortnight. I promise that later this week we'll finish this off... my to-do list is growing quite quickly: viewtopic.php?p=100229#p100229 :)
Postby battye » Sat Mar 27, 2010 7:08 am
I'm back now havocwreaker :)
Could you please post your full make_rsvp.php file (as it is right now) here in code tags.
Postby havocwreaker » Mon Apr 05, 2010 2:33 am
As requested:
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './';
// Start session management
$user->session_begin();
$auth->acl($user->data);
$user->setup('viewforum');
$alert_id = request_var('alert', 0);
   // html
   echo '<html>';
     echo '<head><title>RSVP Page</title>';
echo '    <style type="text/css">
      .graph {
        background-color: #C8C8C8;
        border: solid 1px black;
      .graph td {
        font-family: verdana, arial, sans serif;
      .graph thead th {
        border-bottom: double 3px black;
        padding: 1em;
      .graph tfoot td {
        border-top: solid 1px #999999;
        font-size: x-small;
        text-align: center;
        padding: 0.5em;
        color: #666666;
      .bar {
        background-color: white;
        text-align: right;
        border-left: solid 1px black;
        padding-right: 0.5em;
        width: 400px;
      .bar div {
        border-top: solid 2px #0077DD;
        background-color: #004080;
        border-bottom: solid 2px #002266;
        text-align: right;
        color: white;
        float: left;
        padding-top: 0;
        height: 1em;
      body {
    </style>';
echo '</head>';
   echo '<body bgcolor="#CADCEB">';
if( $alert_id > 0 )
        $rsvp_sql = 'SELECT COUNT(rsvp_id) AS count_rsvp,
                SUM(rsvp_yes_no) AS yes_rsvp, alert_id
                FROM phpbb_alerts_rsvp
                WHERE alert_id = ' . $row['alert_id'];
      $rsvp_result = $db->sql_query($rsvp_sql);
      $rsvp_row = $db->sql_fetchrow($rsvp_result);
      $rsvp_total = $rsvp_row['count_rsvp'];
      $rsvp_yes = $rsvp_row['yes_rsvp'];
      $rsvp_yes = ($rsvp_yes >= 0) ? $rsvp_yes : 0;
      $rsvp_no = $rsvp_total - $rsvp_yes;
      $rsvp_no = ($rsvp_no >= 0) ? $rsvp_no : 0;
      $rsvp_yes_percent = number_format(($rsvp_yes / $rsvp_total), 0);
      $rsvp_no_percent = number_format(($rsvp_no / $rsvp_total), 0);
   echo '<form action="' . append_sid('make_rsvp.'.$phpEx, 'mode=submit') . '" method="post">';
   echo '<h3>RSVP:</h3><br />';
   echo '<input type="radio" name="rsvp" value="1" /> Yes <br />';
   echo '<input type="radio" name="rsvp" value="0" /> No <br /><br />';
   echo '<h3>Explanation:</h3>';
   echo '<input type="text" name="explain" maxlength="255" />';
   echo '<input type="hidden" name="alert_id" value="' . $alert_id . '" />';
   echo '</form>';
   echo '<h3>Statistics:</h3>';
echo '<br /><br /><table width="530" class="graph" cellspacing="6" cellpadding="0">
      <thead>
        <tr><th colspan="3">RSVP statistics</th></tr>
      </thead>
      <tbody>
        <tr>
          <td>Yes</td><td class="bar"><div style="width: ' . $rsvp_yes_percent . '%"></div>' . $rsvp_yes . '</td><td>' . $rsvp_yes_percent . '%</td>
        </tr>
        <tr>
          <td>No</td><td class="bar"><div style="width: ' . $rsvp_no_percent . '%"></div>' . $rsvp_no . '</td><td>' . $rsvp_no_percent . '%</td>
        </tr>
      </tbody>
      <tfoot>
        <tr><td colspan="3">This shows the number of people to have submitted their RSVP.</td></tr>
      </tfoot>
    </table>';
else if( request_var('mode', '') == 'submit' && request_var('alert_id', 0) > 0 )
   $rsvp_array = array(
       'alert_id'            => request_var('alert_id', 0),
      'user_id'            => $user->data['user_id'],
      'username'            => $user->data['username'],
      'rsvp_text'            => request_var('explain', ''),
      'rsvp_yes_no'         => request_var('rsvp', 0),
      'rsvp_time'            => time(),
   $rsvp_sql = 'INSERT INTO phpbb_alerts_rsvp ' . $db->sql_build_array('INSERT', $rsvp_array);
   echo 'Your RSVP has been submitted to the database';
else
   echo 'Invalid id';
   // html
   echo '</body>';
   echo '</html>';
havocwreaker
Frequent Poster
Frequent Poster
Postby battye » Mon Apr 05, 2010 4:09 am
FIND
if( $alert_id > 0 )
REPLACE WITH
if( $alert_id > 0 )
                WHERE alert_id = ' . $alert_id;
(the only change is on that final line, to $alert_id)
That should remove that SQL database error you were getting?
Happy Easter :)
Postby havocwreaker » Tue Apr 06, 2010 1:15 am
File updated. I can't review to see if it works since the developers broke the forum. I will verify once it is running smooth again.
havocwreaker
Frequent Poster
Frequent Poster
Postby havocwreaker » Tue Apr 20, 2010 4:04 am
Site is working as it should now. I apologize for taking so long to get back to you but I was prepping for an event. I didn't get to use the alert mod you mode though. :(
It's active now. Would you care to continue helping me get it so that it works for regions or states?
havocwreaker
Frequent Poster
Frequent Poster
Previous
Return to Web Design
Who is online
Users browsing this forum: No registered users and 0 guests
cron
