Yes this problem only occurs with people that use Internet Explorer. It has to do with the fact that Internet Explorer 6.x doesn't fully support CSS 2.0. Since the website does have some parts that are written with CSS 2.0 and it's not possible to do it in other ways except for frames that I don't want to use. I have to find a work around for it. Before I putted it only it was worse so i'm about half way to fix all the problems that Internet Explorer causes me.
The google ads are to make some money which can hopefully raise me enough to get a real webhost and a domain. They are not ment to annoy you in any way so in the future they will not be above text you want to read.
If you want to check how it is going to be in the near future try to watch it with opera or firefox.
Thx for the comments and keep them coming
I'm also working on some new content, mainly for the problems part of the website. If i'm happy with the result it will be on the website in a few hours.
[size=0].......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... ..........[/size]
Hello
- Red XIII
- Sultan Ruler Of The Poles!
might want to fix the freeware ads all over the place...it kinda cuts into sum of the info! great job otherwise man! keep up the good work!
Red you need to read more carefullyThe google ads are to make some money which can hopefully raise me enough to get a real webhost and a domain. They are not ment to annoy you in any way so in the future they will not be above text you want to read.
Netscape and Mozilla do show it the same since Mozilla is made out of a old version of netscape. There are three main different browsers that all can show things a bit differnt but this mainly goes up for IE that doesn't fully support CSS2 and some other stuff.
I registered a domain and new website can be found here:
http://www.msn-problems.com
You can register at forums if you want and say hello. If you have any MSN Messenger questions I'm happy to try helping you out. It's not finished yet but alot of work has been done.
I can also if possible use help writing articles and stuff so if you want give me a shout.
Umm... I'm surprised you were allowed to register a domain that includes the letters m,s and n in that order. You'd better be careful as you might be contacted in the not-so-distant future about trademarks.
On that topic, I noticed last week that a kids site called http://www.googles.com is suing google on a trademark issue. They say they were in the market first and have failed to get google to talk to them in 6 years. Should be an interesting case.
Oh yeah, and thanks for saying Hi at my site Freggle... it's not what you'd call a "mass appeal" site but it's home.
Oh if they come and tell me to give up the domain i'm happy to receive their 10.000 euro's and switch to another domain or turn this project off at all and go for a new domain.
I don't think they pay you if you're found guilty of stealing trademarks.Freggle wrote:Oh if they come and tell me to give up the domain i'm happy to receive their 10.000 euro's and switch to another domain or turn this project off at all and go for a new domain.
Maybe I'm wrong.
Remember the Mike-Roe-Soft.com case? Microsoft were willing to pay him for that one, so maybe MSN would pay Freggle
