so my problem was i was putting the php code right in the middle of the div. I found the help here: http://www.phpfreaks.com/forums/index.p ... c=317350.0
You cant output the php stuff after the html, it has to be first, so I split up the code like this.
- Code: Select all
<?php include("tester2.php"); ?>
<html>
<head>
<title>Team xO Gaming - Hug's N Kisses!!</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<link rel="stylesheet" href="class.css">
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
function MM_swapImgRestore() { //v3.0
var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
function MM_findObj(n, d) { //v4.01
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
if(!x && d.getElementById) x=d.getElementById(n); return x;
function MM_swapImage() { //v3.0
var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
</head>
<body style="background-color:#000000; margin-top: 0px; margin-bottom: 0px; margin-left: 0px; margin-right: 0px;" onLoad="MM_preloadImages('images/xoweb_over_03.png','images/xoweb_over_04.png','images/xoweb_over_05.png','images/xoweb_over_07.png','images/xoweb_over_08.png','images/xoweb_over_09.png')">
<center>
<div id="Table_01">
<div id="xoweb-01">
<img src="images/xoweb_01.png" width="1000" height="63" alt="">
</div>
<div id="xoweb-02">
<img src="images/xoweb_02.png" width="210" height="81" alt="">
</div>
<div id="xoweb-03"> <a href="#news" target="_self"><img src="images/xoweb_03.png" alt="" width="62" height="33" border="0" id="Image1" onMouseOver="MM_swapImage('Image1','','images/xoweb_over_03.png',1)" onMouseOut="MM_swapImgRestore()"></a>
</div>
<div id="xoweb-04"> <a href="roster.php" target="_self"><img src="images/xoweb_04.png" alt="" width="80" height="33" border="0" id="Image2" onMouseOver="MM_swapImage('Image2','','images/xoweb_over_04.png',1)" onMouseOut="MM_swapImgRestore()"></a>
</div>
<div id="xoweb-05"> <a href="http://www.xo-gaming.com/forum/" target="_new"><img src="images/xoweb_05.png" alt="" width="76" height="33" border="0" id="Image3" onMouseOver="MM_swapImage('Image3','','images/xoweb_over_05.png',1)" onMouseOut="MM_swapImgRestore()"></a>
</div>
<div id="xoweb-06">
<img src="images/xoweb_06.png" width="164" height="81" alt="">
</div>
<div id="xoweb-07"> <a href="#" target="_self"><img src="images/xoweb_07.png" alt="" width="95" height="33" border="0" id="Image4" onMouseOver="MM_swapImage('Image4','','images/xoweb_over_07.png',1)" onMouseOut="MM_swapImgRestore()"></a>
</div>
<div id="xoweb-08"> <a href="#" target="_self"><img src="images/xoweb_08.png" alt="" width="60" height="33" border="0" id="Image5" onMouseOver="MM_swapImage('Image5','','images/xoweb_over_08.png',1)" onMouseOut="MM_swapImgRestore()"></a>
</div>
<div id="xoweb-09"> <a href="http://www.xo-gaming.com/forum/viewforum.php?f=8" target="_self"><img src="images/xoweb_09.png" alt="" width="61" height="33" border="0" id="Image6" onMouseOver="MM_swapImage('Image6','','images/xoweb_over_09.png',1)" onMouseOut="MM_swapImgRestore()"></a>
</div>
<div id="xoweb-10">
<img src="images/xoweb_10.png" width="192" height="81" alt="">
</div>
<div id="xoweb-11">
<img src="images/xoweb_11.png" width="218" height="48" alt="">
</div>
<div id="xoweb-12">
<img src="images/xoweb_12.png" width="216" height="48" alt="">
</div>
<div id="xoweb-13" align="left" >
'body' => 'external_body.html'
page_footer();
<center>© 2011 <a href="http://www.thegiftedape.com/xo/">Team xO,</a> <a href="http://www.thegiftedape.com">TheGiftedApe llc.</a></center></div>
</center>
</body>
</html>
tester2.php code:
- Code: Select all
* home.php
* September 29, 2009
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './forum/';
// Start session management
$user->session_begin();
$auth->acl($user->data);
$user->setup('viewforum');
* posts and topics */
global $db, $auth;
switch($type)
case 'forum':
$type = 'forum_id';
break;
case 'topic':
$type = 'topic_id';
break;
default:
// no restrictions
$out_where = '';
if( $size_gen_id > 0 )
if( $type == 'topic_id' )
unset($gen_id);
$gen_id = $topic_id_list;
$j = 0;
$j++;
return $out_where;
$search_limit = 5;
$forum_id = array(17);
$topic_id = array();
$posts_ary = array(
'SELECT' => 'p.*, t.*',
'FROM' => array(
POSTS_TABLE => 'p',
'LEFT_JOIN' => array(
array(
AND t.topic_approved = 1',
$topic_author = get_username_string('full', $posts_row['topic_poster'], $posts_row['topic_first_poster_name'], $posts_row['topic_first_poster_colour']);
$post_date = $user->format_date($posts_row['post_time']);
$post_link = append_sid("{$phpbb_root_path}viewtopic.$phpEx", "p=" . $posts_row['post_id'] . "#p" . $posts_row['post_id']);
'POST_AUTHOR' => $topic_author,
'POST_DATE' => $post_date,
'POST_LINK' => $post_link,
external body code for those interested:
- Code: Select all
<!-- BEGIN announcements -->
<b><span style="font-size:28px; color:#ccc;">{announcements.TOPIC_TITLE}</span></b><br /><br />
Author: {announcements.POST_AUTHOR}<br />
Date:<b> {announcements.POST_DATE}</b><br />
<br /><b>{announcements.POST_TEXT}</b><br />
<h5><b><a href="{announcements.POST_LINK}">Read/Post Comments</a></b></h5><br /><br /><br />
<!-- END announcements -->
and all the code for pulling the forum articles is in the tester2.php file, works perfectly now and programming the css on the external_body file is super easy. THANK YOU SO MUCH FOR ALL YOUR HELP!!!
The end product can be viewed at http://xo-gaming.com
/thread
