Problem with "Displaying posts and topics on external pages"
Postby powerbonger » Thu Jan 20, 2011 8:06 am
Hi! Total newbie to PHP and MySQL here. A couple of days ago I ran across battye's tutorial on how to display PHPBB3 posts and topics on external pages, found here: http://wiki.phpbb.com/display/MODDOCS/Practical.Displaying+posts+and+topics+on+external+pages
I followed the instructions to the best of my ability (er...copy paste :D ), created a home.php and external_body.html, and went with the code for Example 3, but I kept getting this error:
General Error
SQL ERROR [ mysql4 ]
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'AND t.topic_status <> 2 AND t.topic_approved = 1 ORDER BY ' at line 2 [1064]
An SQL error occurred while fetching this page. Please contact the Board Administrator if this problem persists.
Here is the code I used for home.php (copy-paste goodness):
* home.php
* September 29, 2009
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './phpBB3/';
// Start session management
$user->session_begin();
$auth->acl($user->data);
$user->setup('viewforum');
* posts and topics */
global $db, $auth;
        switch($type)
            case 'forum':
                $type = 'forum_id';
                break;
            case 'topic':
                $type = 'topic_id';
                break;
            default:
    // no restrictions
    $out_where = '';
    if( $size_gen_id > 0 )
        if( $type == 'topic_id' )
            $sql     = 'SELECT topic_id FROM ' . TOPICS_TABLE . '
                        WHERE ' .  $db->sql_in_set('topic_id', $gen_id) . '
                        AND ' .  $db->sql_in_set('forum_id', $auth_f_read);
            $result  = $db->sql_query($sql);
            unset($gen_id);
            $gen_id = $topic_id_list;
    $j = 0;
        $j++;
    return $out_where;
$search_limit = 5;
$forum_id = array(2, 5);
$topic_id = array(20, 50);
$posts_ary = array(
     'SELECT'    => 'p.*, t.*, u.username, u.user_colour',
     'FROM'      => array(
         POSTS_TABLE     => 'p',
     'LEFT_JOIN' => array(
         array(
             'FROM'  => array(USERS_TABLE => 'u'),
             'ON'    => 'u.user_id = p.poster_id'
         array(
             'FROM'  => array(TOPICS_TABLE => 't'),
             'ON'    => 'p.topic_id = t.topic_id'
     'WHERE'     =>  str_replace( array('WHERE ', 'topic_id'), array('', 't.topic_id'), $topic_id_where) . '
                     AND t.topic_approved = 1',
     'ORDER_BY'  => 'p.post_id DESC',
      $topic_title       = $posts_row['topic_title'];
      $post_author       = get_username_string('full', $posts_row['poster_id'], $posts_row['username'], $posts_row['user_colour']);
      $post_date          = $user->format_date($posts_row['post_time']);
      $post_link       = append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . $posts_row['forum_id'] . '&amp;t=' . $posts_row['topic_id'] . '&amp;p=' . $posts_row['post_id']) . '#p' . $posts_row['post_id'];
      'TOPIC_TITLE'       => censor_text($topic_title),
      'POST_AUTHOR'       => $post_author,
      'POST_DATE'       => $post_date,
      'POST_LINK'       => $post_link,
      'POST_TEXT'         => censor_text($post_text),
    page_header('External page');
        'body' => 'external_body.html'
    page_footer();
And, just in case, here is the code for my external_body.html (which is located in the \prosilver\template\ folder of my phpbb3 directory:
<!-- BEGIN announcements -->
Title: {announcements.TOPIC_TITLE}<br />
Post author: {announcements.TOPIC_AUTHOR}<br />
Post date: {announcements.POST_DATE}<br />
Last post text: {announcements.POST_TEXT}<br />
Post link: {announcements.POST_LINK}
<!-- END announcements -->
Can anyone show me where I went wrong? I'm still new to this, and would greatly appreciate any help. :)
Regards,
powerbonger
powerbonger
Re: Problem with "Displaying posts and topics on external pa
Postby powerbonger » Thu Jan 20, 2011 8:09 am
Oh, to add, when I tried to use the code for Example 4 on the same file above (replaced the code from Example 3), it worked as intended, and the error didn't show up. :?
powerbonger
Postby battye » Thu Jan 20, 2011 1:40 pm
Hmm, that is strange. I tested all of the examples before I published any of them online, and I'm not immediately seeing what the problem could be.
Could you try removing this line:
And letting me know if you still get the SQL error?
Welcome to the forum powerbonger, feel free to check out OT Forum if you haven't already had the chance :)
Postby vaalsh » Fri Aug 12, 2011 8:31 am
Hi!
Script works fine on a separate page, but when i am trying to put it (include "home.php") on main page
of my site, I am getting error:
<< in file /includes/functions.php on line 4284: Cannot modify header information - headers already sent by (output started at index_test.html:6) >>
Any help greatly appreciated!
vaalsh
Postby battye » Sat Aug 13, 2011 4:26 pm
Can you please post the first 10 lines of index_test.html?
Postby maxpayen » Wed Sep 16, 2020 7:12 am
Hi all,
I'm new to the board and new to forum creation/management in general. I am designing an external site for a client and they would like to have a portion of the homepage display the latest posts from their new ProPhPBB forum that I created for them. Apparently, I'm unable to post URLs in my first post so I'll post again in this thread with the tutorial I'm trying to follow.
Thanks!
Get fast, free Geico Car Insurance Quotes today. Find affordable insurance coverage for your car, motorcycle, and much more.
maxpayen
Return to Web Design
Who is online
Users browsing this forum: No registered users and 2 guests
cron
