Re: UQM 2.0 - Predictions Extensions
Postby subvertbeats » Sat Jan 23, 2010 11:43 am
Thanks moongirl !!
battye wrote:Cheating attempts happen because you refreshed the quiz submission page. It is to stop people from refreshing the page in order to reset the time limit. So don't ever refresh a quiz page :wink:
battye....where should I be looking to relax the cheating detection.
Specifically I only want to stop people SUBMITTING a competition more than once.
It should be fine for them to load a quiz to look at questions then revisit the page later to enter.
Thanks!
subvertbeats
Postby moongirl » Sun Jan 24, 2010 3:49 am
subvertbeats wrote:Thanks moongirl !!
You're welcome :wink:
Click To Play Online-Scrabble - Click To Play Quizzes
~~~In the year 2040...I'll have 100,000 posts!!~~~
Postby battye » Mon Jan 25, 2010 1:52 am
subvertbeats wrote:One usage question on this battye....
If a match is cancelled, perhaps mid way through the week, when the comp is still open and lots of people have made their votes already, what is the correct procedure to remove that question from the comp (or mark it as invalid if removal is not possible), such that future entrants dont vote on that particular match, and most importantly, so the results for that particular match are not counted?
Thanks for your advice...
In this instance, set the quiz to inactive (using the script I wrote) and don't ever "enter the answers" for it. So results will never be counted.
Thanks!
I don't recommend doing this, but if you must:
OPEN quiz.php
trigger_error($user->lang['CHEATING_ATTEMPT']);
REPLACE WITH
//trigger_error($user->lang['CHEATING_ATTEMPT']);
Postby subvertbeats » Mon Jan 25, 2010 2:14 am
Hi battye, I hope your weekend has been good.....thanks for the reply...
Sorry, what I mean here is that one match from an event may have been cancelled, or changed at some point mid way through the competition being open. In that case, you want to ignore/disable/delete that question from the quiz, whilst leaving the other matches (questions) active in the quiz.
battye wrote:
subvertbeats wrote:battye....where should I be looking to relax the cheating detection.
Thanks!
Why is this not recommended (given the different usage context, and the fact we dont have any kind of time limit in action?)
Thanks!
subvertbeats
Postby battye » Mon Jan 25, 2010 6:57 am
OPEN quiz.php
FIND around line 60
REPLACE WITH
               while( $row = $db->sql_fetchrow($result) && $_POST['question' . $question_id_set[$i]] != 'cancelled' )
Then if a match is cancelled, enter the word cancelled as the answer.
Postby subvertbeats » Mon Jan 25, 2010 9:18 am
So Id first edit the question so that 'Cancelled' is one of the multiple choice options for that question (maybe replaced 'Draw' with 'Cancelled')?
Then re-enter the answer using ?mode=enter_answers, and select the 'cancelled' option for that question?
Also, just to confirm that re-entering the answers should not cause any duplicate statistics to be recorded?
subvertbeats
Postby battye » Mon Jan 25, 2010 10:04 am
Yes, use a lower case "c".
I don't think it should.
Postby subvertbeats » Mon Jan 25, 2010 1:43 pm
battye wrote:OPEN quiz.php
FIND around line 60
REPLACE WITH
thanks (again!) battye....
One q on this....
You say quiz.php, around line 60
In my quiz.php, these lines occur around line 1140.
In control_quiz.php, they occur around line 60.
Im thinking this change needs to be in control_quiz.php, but it would be great if you could confirm that.
subvertbeats
Postby battye » Mon Jan 25, 2010 1:44 pm
Yes, I meant the one I wrote for you. Sorry for the confusion.
Postby subvertbeats » Mon Feb 01, 2010 1:15 pm
Hi battye
Im about to patch this custom version upto beta 4, but before I do thought id try and resolve an issue.
Ive just run our first competition...60 or so entries, 11 questions (predictions).
I closed the competition successfully.
Today Ive come to enter the correct answers, and Im getting this SQL error:
SQL ERROR [ mysql4 ]
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 2 [1064]
SQL
SELECT username FROM phpbb_users WHERE user_id =
BACKTRACE
FILE: includes/db/mysql.php
LINE: 174
CALL: dbal->sql_error()
FILE: control_quiz.php
LINE: 66
CALL: dbal_mysql->sql_query()
quiz.php:
* @package phpBB3
* @version $Id: quiz.php
* @copyright (c) 2008, 2009 battye, CricketMX.com
* Ultimate Quiz MOD v2.0.0
* @license http://opensource.org/licenses/gpl-license.php GNU Public License
* @ignore
include($phpbb_root_path . 'includes/functions_quiz.' . $phpEx);
$user->session_begin();
$auth->acl($user->data);
$user->setup('mods/quiz');
error_reporting(E_ALL | E_NOTICE);
// Grab data
$mode = request_var('mode', '');
$action = request_var('action', '');
$category = request_var('category', 0);
if( !$user->data['is_registered'] )
trigger_error('QUIZ_MUST_BE_LOGGED_IN');
   // Find which mode is set
   if ($mode == 'submit')
   // submit quiz
   // First of all, check if the admin only setting is enabled.
   // If so, only admins can access this page.
   if( $config['quiz_admin_only_submit'] != 0 && !$auth->acl_get('a_') )
      trigger_error($user->lang['QUIZ_ADMIN_SUBMIT_ONLY_ERROR']);
   // Sort bbCode
   $uid = $bitfield = $options = '';
   $allow_bbcode = $allow_urls = $allow_smilies = true;
   // uid - $uid, bitfield - $bitfield, options - $options
   page_header($user->lang['SUBMIT_QUIZ']);
      if( $action == 'submit' ) // The actual submission to the database stage
      $data_array = array();
      $full_correct_array = array();
      $full_correct_array_count = 0;
      $number_of_questions = request_var('number_of_questions', 0);
      $this_quiz_id = quiz_latest_id() + 1;
         if (!($number_of_questions > 0))
            trigger_error($user->lang['NUMBER_QUESTIONS_UNDEFINED']);
         for ($e = 1; $e <= $number_of_questions; $e++) // Just a trial run to make sure all questions are submitted
            if (!request_var('question_name_' . $e, '', true))
               trigger_error($user->lang['EMPTY_QUESTION']);
         for ($i = 1; $i <= $number_of_questions; $i++)
         $question_name = request_var('question_name_' . $i, '', true);
            if (request_var('answers_' . $i, '', true)) // input answer or multiple choice
               $correct_answer = request_var('mc_' . $i, '', true);
               $multiple_answers = request_var('answers_' . $i, '', true);
               $multiple_answers_array = explode("\n", $multiple_answers);
            else if (request_var('tf_' . $i, 0) != 0) // true/false
               $correct_answer = (request_var('tf_' . $i, 0) == 1) ? $user->lang['TRUE_FALSE_TRUE'] : $user->lang['TRUE_FALSE_FALSE'];
               $multiple_answers_array = array($user->lang['TRUE_FALSE_TRUE'], $user->lang['TRUE_FALSE_FALSE']);
               // Update questions table
               generate_text_for_storage($question_name, $uid, $bitfield, $options, $allow_bbcode, $allow_urls, $allow_smilies);
               $question_array = array(
                   'quiz_question'         => utf8_normalize_nfc($question_name),
                   'quiz_related_id'      => $this_quiz_id,
                  'quiz_uid'            => $uid,
                  'quiz_bitfield'         => $bitfield,
                  'quiz_options'         => $options
               $question_sql = 'INSERT INTO ' . QUIZ_QUESTIONS_TABLE . ' ' . $db->sql_build_array('INSERT', $question_array);
               $db->sql_query($question_sql);
               //$that_question_id = $db->sql_nextid() - 1; // This is the ID of the question submitted now.
               $that_question_id = $db->sql_nextid();
               // Now the actual data
               $multiple_answers_array_number = sizeof($multiple_answers_array);
                  // For those people who submit too many choices
                  $key = 0;
                  if( $multiple_answers_array_number > $config['quiz_submit_max_multiple_choice'] )
                     $key = array_search($correct_answer, $multiple_answers_array);
                     $key++;
                     $how_many_further = $multiple_answers_array_number - $config['quiz_submit_max_multiple_choice'];
                  $stop_further_checks = 0;
                  for ($k = 0; $k < $multiple_answers_array_number; $k++)
                     /* Initialise any remaining variables, avoid offset */
                     if( !isset($remove_question) )
                        $remove_question = 0;
                     // If key is set, we need to remove one of the incorrect answers
                     if ($key > 0 && $stop_further_checks != 1)
                        if ( ($key-1) != $k ) // If it is not the correct answer then we remove this one
                           $remove_question = 1; // yes
                           $how_many_further = $how_many_further - 1;
                              if ($how_many_further == 0)
                                 $stop_further_checks = 1; // don't check any more
                                 $stop_further_checks = 0; // keep going
                     if ( $remove_question != 1 )
                     $correct_true_input_question_answer = ($multiple_answers_array[$k] == $correct_answer) ? true : false;
                     generate_text_for_storage($multiple_answers_array[$k], $uid, $bitfield, $options, $allow_bbcode, $allow_urls, $allow_smilies);
                        $data_array[] = array(
                            'quiz_question_id'      => $that_question_id,
                            'quiz_answer'          => utf8_normalize_nfc($multiple_answers_array[$k]),
                           'quiz_correct'         => $correct_true_input_question_answer,
                           'quiz_uid'            => $uid,
                           'quiz_options'         => $options,
         // End the looping of the separate questions
      $db->sql_multi_insert(QUIZ_DATA_TABLE, $data_array);
      // Insert into main quiz table.
      $quiz_category    = request_var('select_category', 0);
      $quiz_name       = request_var('quiz_name', '', true);
      $quiz_array = array(
          'quiz_author'            => $user->data['user_id'],
          'quiz_category'            => $quiz_category,
          'quiz_name'             => $quiz_name,
         'quiz_date'               => time(),
         'quiz_number_of_questions'    => $number_of_questions,
          'quiz_views'             => 0
      $quiz_sql = 'INSERT INTO ' . QUIZ_TABLE . ' ' . $db->sql_build_array('INSERT', $quiz_array);
      $db->sql_query($quiz_sql);
      // update the latest quiz id
      set_config('quiz_latest_id_submitted', ($config['quiz_latest_id_submitted'] + 1));
      trigger_error(sprintf($user->lang['QUIZ_SUBMISSION_SUCCESSFUL'], '<a href="' . append_sid('quiz.'.$phpEx) . '">', '</a>')); // The quiz was successfully entered into the database
      if( $action == 'verify' )
         $true_false_questions = '';
         // ready to submit?
         if( request_var('final_verification', 0) )
         $readiness_fv = 1; // true by default
            if( !request_var('quiz_name', '', true) || !request_var('select_category', '') || request_var('select_category', '') == 'undefined' )
               // We are not ready
               $readiness_fv = 0;
            else // check the questions that answers have been selected
               for ($r = 1; $r <= $number_of_questions; $r++)
                  if( !request_var('tf_' . $r, 0) && !request_var('mc_' . $r, '', true) )
                     // Not ready here either
                     $readiness_fv = 0;
            if( $readiness_fv )
               // Define the quiz type
               $reveal_multiples_row = '';
               if( request_var('tf_' . $r, 0) )
                  $reveal_quiz_type = $user->lang['IS_TRUE_FALSE'];
               else if ( strpos(request_var('answers_' . $r, '', true), "\n") )
                  $multi_list = explode("\n", request_var('answers_' . $r, '', true));
                  $alternates_list = '';
                  for ($b = 0; $b < sizeof($multi_list); $b++)
                     $multi_list[$b] = ($multi_list[$b] == request_var('mc_' . $r, '', true)) ? '' : $multi_list[$b];
                     $alternates_list .= ($multi_list[$b] != '') ? ', ' . $multi_list[$b] : '';
                  $alternates_list[0] = '';
                  $alternates_list[1] = '';
                  generate_text_for_storage($alternates_list, $uid, $bitfield, $options, $allow_bbcode, $allow_urls, $allow_smilies);
                  $alternates_list = generate_text_for_display($alternates_list, $uid, $bitfield, $options, $allow_bbcode, $allow_urls, $allow_smilies);
                  $reveal_quiz_type = $user->lang['MULTIPLE_CHOICE_QUESTION'];
                  $reveal_multiples_row .= $alternates_list;
                  $reveal_quiz_type = $user->lang['INPUT_ANSWER_QUESTION'];
               // Create bbCode for question
               $reveal_name_of_quiz = request_var('question_name_' . $r, '', true);
               generate_text_for_storage($reveal_name_of_quiz, $uid, $bitfield, $options, $allow_bbcode, $allow_urls, $allow_smilies);
               $reveal_name_of_quiz = generate_text_for_display($reveal_name_of_quiz, $uid, $bitfield, $options, $allow_bbcode, $allow_urls, $allow_smilies);
               // Create bbCode for correct answer
               $reveal_correct_answer_for_question = request_var('mc_' . $r, '', true);
               generate_text_for_storage($reveal_correct_answer_for_question, $uid, $bitfield, $options, $allow_bbcode, $allow_urls, $allow_smilies);
               $reveal_correct_answer_for_question = generate_text_for_display($reveal_correct_answer_for_question, $uid, $bitfield, $options, $allow_bbcode, $allow_urls, $allow_smilies);
               $template->assign_block_vars('question_row', array(
               'QUESTION_ID'            => $r,
               'QUIZ_TYPE'               => $reveal_quiz_type,
               'QUESTION_NAME_REVEAL'      => $reveal_name_of_quiz,
               'QUESTION_NAME_HIDDEN'      => '<input type="hidden" name="question_name_' . $r . '" value="' . request_var('question_name_' . $r, '', true) . '" />',
               'QUESTION_ANSWER_REVEAL'   => (request_var('tf_' . $r, 0) != 0) ? ((request_var('tf_' . $r, 0) == 1) ? $user->lang['TRUE_FALSE_TRUE'] : $user->lang['TRUE_FALSE_FALSE']) : $reveal_correct_answer_for_question,
               'MULTIPLES_REVEAL'         => $reveal_multiples_row,
               'QUESTION_ANSWER_HIDDEN'   => (request_var('tf_' . $r, 0) != 0) ? '<input type="hidden" name="tf_' . $r . '" value="' . request_var('tf_' . $r, '') . '" />' : '<input type="hidden" name="answers_' . $r . '" value="' . request_var('answers_' . $r, '', true) . '" /><input type="hidden" name="mc_' . $r . '" value="' . request_var('mc_' . $r, '', true) . '" />',
              $s_hidden_fields = build_hidden_fields(array(
                  'number_of_questions'      => $number_of_questions,
               'S_SUBMIT_QUIZ_ACTION'       => append_sid("{$phpbb_root_path}quiz.$phpEx", 'mode=submit&amp;action=submit'),
               'S_HIDDEN_FIELDS'         => $s_hidden_fields,
               'L_SUBMIT_INFORMATION'      => $user->lang['FINAL_VERIFY_SUBMIT'],
               'U_STEP_SUBMIT_QUIZ'      => $user->lang['SUBMIT_STEP_3'],
               'U_CHECK_INITIAL'          => false,
               'U_VERIFY_ANSWERS'         => false,
               'U_FINAL_VERIFY'          => true,
               'U_QUIZ_NAME'            => request_var('quiz_name', '', true),
               'U_FINAL_CATEGORY_NAME'      => get_category_name(request_var('select_category', 0)),
               'U_FINAL_CATEGORY_ID'      => request_var('select_category', 0),
               'U_SELECT_A_CATEGORY'      => quiz_category_list(request_var('select_category', 0)),
               'body' => 'quiz_submit_body.html')
            page_footer();
      /* Initialise any remaining variables */
      if( !isset($readiness_fv) )
         $readiness_fv = 0;
      if( !$readiness_fv && !request_var('final_verification', 0) )
         // let's check to make sure all of the questions have been filled out. Also that multiple choice is correct
         for ($q = 1; $q <= $number_of_questions; $q++)
            // is the question/answer actually filled out for all questions?
            $verify_ok = ( request_var('question_name_' . $q, '', true) != '' && ( request_var('answers_' . $q, '', true) != '' || request_var('is_true_false_' . $q, 0) == 1 ) ) ? 1 : 0;   // 0 represents something is empty
            $multiple_choices = ( request_var('answers_' . $q, '', true) ) ? explode("\n", request_var('answers_' . $q, '', true)) : '';
            $number_of_multiple_choices = sizeof($multiple_choices);
            $mc_alert = ($number_of_multiple_choices > $config['quiz_submit_max_multiple_choice']) ? sprintf($user->lang['TOO_MANY_CHOICES'], $config['quiz_submit_max_multiple_choice']) : '';
            if ($verify_ok == 0 || $number_of_multiple_choices > $config['quiz_submit_max_multiple_choice'])
            break;
      if ((!$readiness_fv && !request_var('final_verification', 0)) && (!$verify_ok || $number_of_multiple_choices > $config['quiz_submit_max_multiple_choice']))
      $submit_quiz_action_figure = "verify";
      $final_quiz_verification = false;
            'S_HIDDEN_ANSWERS'   => @$hidden_field,
            'QUESTION_ID'      => $i,
            'QUESTION_NAME'      => request_var('question_name_' . $i, '', true),
            'QUESTION_TF_CHECK'   => (request_var('is_true_false_' . $i, 0) == 1) ? 'checked="checked"' : false, // Display true or false option
            'QUESTION_ANSWER'   => request_var('answers_' . $i, '', true),
         // Deciding the error message
         $ef_error_msg = ( !$verify_ok ) ? $user->lang['EMPTY_QUIZ_FIELDS'] : $mc_alert;
         $verify_ok = false; // Just in case it was the multiple choice that caused this, to be used later on
            'U_EMPTY_FIELDS'      => true,
            'U_EMPTY_FIELDS_MSG'   => $ef_error_msg,
            'L_SUBMIT_INFORMATION'   => sprintf( $user->lang['SUBMIT_INFORMATION'], $number_of_questions, $config['quiz_submit_max_multiple_choice'] ),
      $final_quiz_verification = true;
      // If we are on Step 2 "retry", ie. referred back to this page, we need to check for the existance of true/false questions
      $tf_questions_expl = explode(',', request_var('true_false_questions', ''));
            if ( request_var('question_name_' . $i, '', true) || request_var('answers_' . $i, '', true) && ( !request_var('final_verification', 0) && (request_var('is_true_false_' . $i, 0) == 1) ))
               if (request_var('is_true_false_' . $i, 0) == 1)
                  $true_false_questions .= $i . ',';
                  $hidden_field = '<input type="hidden" name="answers_' . $i . '" value="' . request_var('answers_' . $i, '', true) . '" />';
                  $multiple_choices = ( request_var('answers_' . $i, '', true) ) ? explode("\n", request_var('answers_' . $i, '', true)) : '';
                  //$mc_alert = ($number_of_multiple_choices > $config['quiz_submit_max_multiple_choice']) ? sprintf($user->lang['TOO_MANY_CHOICES'], $config['quiz_submit_max_multiple_choice']) : '';
                  if ($number_of_multiple_choices == 1) // If the quiz is input answer, this will apply
                     //$create_offsetted_mc = (isset($multiple_choices[0])) ? $multiple_choices[0] : '';
                     //$multiple_choice_lineup = $create_offsetted_mc . '<input type="hidden" name="mc_'.$i.'" value="' . $create_offsetted_mc . '" />';
                     @$multiple_choice_lineup = $multiple_choices[0] . '<input type="hidden" name="mc_'.$i.'" value="' . $multiple_choices[0] . '" />';
                  else // for deciding multiple choice options
                     $multiple_choice_lineup = '';
                     for ($x = 0; $x < $number_of_multiple_choices; $x++)
                        if( $multiple_choices[$x] == '' || $multiple_choices[$x] == ' ' )
                           trigger_error($user->lang['EMPTY_ANSWER']);
                        $multiple_choice_lineup .= '<input type="radio" name="mc_'.$i.'" value="' . $multiple_choices[$x] . '" /> ' . $multiple_choices[$x] . '<br />';
               if ( !$true_false_questions && request_var('true_false_questions', '') )
                  $true_false_questions = request_var('true_false_questions', '');
               $question_tf_vp = false;
               // is_numeric must be used in case it is the 0th item in the array
               if( request_var('is_true_false_' . $i, 0) == 1 || (!((!$readiness_fv && !request_var('final_verification', 0))) && is_numeric(array_search(($i), $tf_questions_expl))) )
                  $question_tf_vp = true;
                  'QUESTION_TF'      => $question_tf_vp, // Display true or false option
                  'QUESTION_MC'      => (isset($multiple_choice_lineup)) ? $multiple_choice_lineup : '', // Display a list of multiple choices or the input answer
                  // 'QUESTION_MC_ALERT'   => $mc_alert,
            'true_false_questions'      => $true_false_questions,
            'final_verification'      => $final_quiz_verification,
            'S_SUBMIT_QUIZ_ACTION'       => append_sid("{$phpbb_root_path}quiz.$phpEx", 'mode=submit&amp;action=' . $submit_quiz_action_figure),
            'U_STEP_SUBMIT_QUIZ'      => $user->lang['SUBMIT_STEP_2'],
            'U_EMPTY_FIELDS'         => ((!$readiness_fv && !request_var('final_verification', 0))) ? false : true,
            'U_EMPTY_FIELDS_MSG'      => $user->lang['EMPTY_RADIO_BOX'],
            'U_VERIFY_ANSWERS'         => ((!$readiness_fv && !request_var('final_verification', 0))) ? $verify_ok : true,
         if (!request_var('number_of_questions', 0))
         // initial "choose number of questions screen"
         // quahappy's suggestion to use a drop down box
         $num_drop = '<select name="number_of_questions">';
         for ($d = $config['quiz_submit_min']; $d <= $config['quiz_submit_max']; $d++)
            $num_drop .= '   <option value="' . $d . '">' . $d . '</option>';
         $num_drop .= '</select>';
               'L_SELECT_NUMBER_EXPLAIN'   => sprintf($user->lang['SELECT_NUMBER_EXPLAIN'], $config['quiz_submit_min'], $config['quiz_submit_max']),
               'S_SUBMIT_QUIZ_ACTION'       => append_sid("{$phpbb_root_path}quiz.$phpEx", 'mode=submit'),
               'U_STEP_SUBMIT_QUIZ'      => $user->lang['SUBMIT_QUIZ'],
               'U_CHECK_INITIAL'          => true,
               'U_NUM_DROP'            => $num_drop,
         // actual adding questions and answers screen
         // check to make sure it is within required parameters
         if (!request_var('number_of_questions', 0) || $number_of_questions < $config['quiz_submit_min'] || $number_of_questions > $config['quiz_submit_max'])
            trigger_error( sprintf($user->lang['OUTSIDE_QUESTION_PARAM'], $config['quiz_submit_min'], $config['quiz_submit_max']) );
            for ($i = 0; $i < $number_of_questions; $i++)
                  'QUESTION_ID'   => $i + 1,
               'S_SUBMIT_QUIZ_ACTION'    => append_sid("{$phpbb_root_path}quiz.$phpEx", 'mode=submit&amp;action=verify'),
               'U_STEP_SUBMIT_QUIZ'   => $user->lang['SUBMIT_STEP_1'],
               'U_SELECT_A_CATEGORY'   => quiz_category_list(''),
               'U_MAX_MULTIPLE_CHOICE'   => $config['quiz_submit_max_multiple_choice'],
   if ($mode == 'play')
      // Quiz play once
      if( $config['quiz_play_once'] != 0 )
         $check_once = 'SELECT quiz_stats_id
                     FROM ' . QUIZ_STATISTICS_TABLE . '
                     WHERE quiz_id = ' . request_var('q', 0) . '
                     AND quiz_player = ' . $user->data['user_id'] . '
                     ORDER BY quiz_stats_id DESC';
         $check_once_result = $db->sql_query_limit($check_once, 1);
         $check_once_id = $db->sql_fetchfield('quiz_stats_id');
         if( (int) $check_once_id > 0 )
            trigger_error(sprintf($user->lang['QUIZ_PLAY_ONCE_ONLY'], '<a href="' . append_sid('quiz.'.$phpEx) . '">', '</a>'));
      if( $config['quiz_play_own_quiz'] == 0 )
         if( get_author_of_quiz(request_var('q', 0)) == $user->data['user_id'] || get_author_of_quiz(request_var('quiz_id', 0)) == $user->data['user_id'] )
            trigger_error($user->lang['QUIZ_USER_CANNOT_PLAY_OWN']);
      // active check
      $act_sql = 'SELECT quiz_deactivate FROM ' . QUIZ_TABLE . ' WHERE quiz_id = ' . request_var('q', 0);
      $act_res = $db->sql_query($act_sql);
      $act_check_look = $db->sql_fetchfield('quiz_deactivate');
      if( $act_check_look > 0 )
      trigger_error("This competition is closed");
      if ($action == 'submit')
      // The save type - "save" or "submit".
      $save_type = request_var('submit', '');
      $quiz_id = request_var('quiz_id', 0);
      $current_quiz_in_progress_check = find_current_live_progress_id($quiz_id, 1);
         if (!$current_quiz_in_progress_check)
            trigger_error($user->lang['MULTIPLE_SUBMISSION']);
      $find_number_of_questions_in_quiz = find_number_of_questions_in_quiz($quiz_id);
      $quiz_start_time = find_current_live_progress_id($quiz_id, 2); // When "2", the unix timestamp of the start time is given
      $time_taken_to_do_quiz = time() - $quiz_start_time + find_current_live_progress_id($quiz_id, 3);
         if ($config['quiz_save_enabled'] == '1' && $save_type == $user->lang['QUIZ_SAVE'])
            if ($config['quiz_time_limit_per_question'] != '0')
               if ($time_taken_to_do_quiz > ($config['quiz_time_limit_per_question'] * $find_number_of_questions_in_quiz))
               $db->sql_query("UPDATE " . QUIZ_PROGRESSIVE_TABLE . " SET quiz_in_progress = 0 WHERE quiz_progress_id = " . $current_quiz_in_progress_check);
               trigger_error(sprintf($user->lang['QUIZ_TIME_EXCEEDED'], $time_taken_to_do_quiz));
         $saved_input = '';
            // Essentially a rehash of what is below, but saved.
            $sql = "SELECT quiz_question_id
                  FROM " . QUIZ_QUESTIONS_TABLE . "
                  WHERE quiz_related_id = " . $quiz_id;
            while ($question_id_array = $db->sql_fetchrow($result))
            $give_question_id = $question_id_array['quiz_question_id'];
            $given_user_input = request_var('question' . $give_question_id, '');
            $user_given_answer = (!is_numeric($given_user_input)) ? $given_user_input : correct_answer_for_id($given_user_input, 2);
            $saved_input .= $give_question_id . ':/\:/\:/\:' . $user_given_answer . ';/\;/\;/\;';
         $sql = "UPDATE " . QUIZ_PROGRESSIVE_TABLE . "
               SET quiz_progress_saved = '" . $db->sql_escape($saved_input) . "',
               quiz_progress_stop_time = " . time() . ",
               quiz_time_used = " . $time_taken_to_do_quiz . "
               WHERE quiz_progress_id = " . find_current_live_progress_id($quiz_id, 1);
         trigger_error($user->lang['QUIZ_PROGRESS_SAVED']);
         else if ($save_type == $user->lang['SUBMIT'])
         page_header($user->lang['QUIZ_RESULTS']);
         $time_results_summary = sprintf($user->lang['TIME_SUMMARY'], $time_taken_to_do_quiz);
         $submit_quiz_progressive_id = find_current_live_progress_id($quiz_id, 1);
         // Before we do anything, let's see if the time limits stuff is alright
            //if ($time_taken_to_do_quiz > (($config['quiz_time_limit_per_question'] * $find_number_of_questions_in_quiz) - find_current_live_progress_id($quiz_id, 3)))
               $db->sql_query("UPDATE " . QUIZ_PROGRESSIVE_TABLE . " SET quiz_in_progress = 0 WHERE quiz_progress_id = " . $submit_quiz_progressive_id);
         $number_of_correct_answers = 0;
         $number_of_incorrect_answers = 0;
         $show_answers = array();
         $statistical_sql = array();
            $given_user_input = request_var('question' . $give_question_id, ''); // raw input
                  // if it is input answer, we need to combat inputting "numbers"
                  $type_sql = "SELECT COUNT(quiz_data_id) AS quiz_type FROM " . QUIZ_DATA_TABLE . "
                           WHERE quiz_question_id = " . intval($give_question_id);
                  $type_result = $db->sql_query($type_sql);
                  $determine_quiz_type = $db->sql_fetchfield('quiz_type');
                  $db->sql_freeresult($type_result);
            // true/false or multiple choice
            if( $determine_quiz_type > 1 )
               $user_given_answer = (!is_numeric($given_user_input)) ? $given_user_input : correct_answer_for_id($given_user_input, 2); // the answer the user chose or gave
            // input answer
               // $user_given_answer = (int) $given_user_input;
               $user_given_answer = $given_user_input;
            $actual_correct_answer = correct_answer_for_id($give_question_id, 1); // the correct (database) answer
               if (utf8_case_fold_nfc($user_given_answer) == utf8_case_fold_nfc($actual_correct_answer))
                  if ($config['quiz_show_answers'] != '0') // Should we show the answers to the user? Err...
                     $show_answers[($number_of_correct_answers + $number_of_incorrect_answers)] = sprintf($user->lang['SHOW_RESULTS_CORRECT'], $user_given_answer);
                  $statistical_array = array(
                       'quiz_question_id'         => (int) $give_question_id,
                     'quiz_id'               => (int) $quiz_id,
                       'quiz_correct'            => 1,
                       'quiz_answer'            => $user_given_answer,
                       'quiz_player'            => (int) $user->data['user_id'],
                  $number_of_correct_answers++;
                     $show_answers[($number_of_correct_answers + $number_of_incorrect_answers)] = sprintf($user->lang['SHOW_RESULTS_INCORRECT'], $user_given_answer, $actual_correct_answer);
                       'quiz_correct'            => 0,
                  $number_of_incorrect_answers++;
            $statistical_sql[] = 'INSERT INTO ' . QUIZ_STATISTICS_TABLE . '
                             ' . $db->sql_build_array('INSERT', $statistical_array);
            $db->sql_freeresult($result);
               // the basic stats (right/wrong in a quiz for quick reference)
               $statistical_overview_setup = array(
                    'quiz_correct'      => (int) $number_of_correct_answers,
                    'quiz_incorrect'   => (int) $number_of_incorrect_answers,
                  'user_id'         => (int) $user->data['user_id'],
                  'quiz_time'         => (int) $time_taken_to_do_quiz,
            //$statistical_sql[] = 'INSERT INTO ' . QUIZ_STATISTICS_OVERVIEW_TABLE . '
            //                 ' . $db->sql_build_array('INSERT', $statistical_overview_setup);
            // For compatibility with cash, a lot of people want this feature
            $cash_summary = '';
            if( $config['quiz_cash_on'] != 0 )
               $cash_gained_or_lost = ($number_of_correct_answers * (int) $config['quiz_cash_win']) - ($number_of_incorrect_answers * (int) $config['quiz_cash_lose']);
               $cash_field = 'user_points';
               $statistical_sql[] = "UPDATE " . USERS_TABLE . " SET $cash_field = $cash_field + $cash_gained_or_lost WHERE user_id = " . $user->data['user_id'];
               if( $cash_gained_or_lost >= 0 )
                  $cash_summary = '<br />' . sprintf($user->lang['QUIZ_POINTS_CASH_SUMMARY_WON'], $cash_gained_or_lost);
                  $cash_summary = '<br />' . sprintf($user->lang['QUIZ_POINTS_CASH_SUMMARY_LOST'], (0-$cash_gained_or_lost));
         $results_summary = sprintf($user->lang['RESULTS_SUMMARY'], $number_of_correct_answers, $number_of_incorrect_answers);
               if ($config['quiz_show_answers'] != '0') // Ctrl+V. I mean, " // Should we show the answers to the user? Err..."
                  $sql = "SELECT * FROM " . QUIZ_QUESTIONS_TABLE . "
                        WHERE quiz_related_id = $quiz_id
                        ORDER BY quiz_question_id ASC";
                  // Loops the questions, so we can display the answer
                  $n = 0;
                     $question_formatted = generate_text_for_display($row['quiz_question'], $row['quiz_uid'], $row['quiz_bitfield'], $row['quiz_options']); // does this look familiar? lets format the question
                     $user_result = $show_answers[$n];
                     $template->assign_block_vars('results_row', array(
                        'QUESTION'         => $question_formatted,
                        'RESULT'         => $user_result,
                  $n++;
               'U_QUIZ_RESULTS_WITH_NAME'   => sprintf($user->lang['QUIZ_RESULTS_WITH_NAME'], get_quiz_title($quiz_id)),
               'SHOW_ANSWERS'            => ($config['quiz_show_answers'] != '0') ? true : false,
               'TIME_SUMMARY'            => $time_results_summary,
               'RESULTS_SUMMARY'         => $results_summary,
               'CASH_SUMMARY'            => $cash_summary,
               'body' => 'quiz_results_body.html')
         // Delete all temporary/progressive data and update the view count of the quiz
         // We'll use the stats array as it looks nicer, and loosely related anyway
         $statistical_sql[] = "DELETE FROM " . QUIZ_PROGRESSIVE_TABLE . " WHERE quiz_progress_id = $submit_quiz_progressive_id";
         $statistical_sql[] = "UPDATE " . QUIZ_TABLE . " SET quiz_views = quiz_views + 1 WHERE quiz_id = $quiz_id";
         // Insert statistics
         $size_statistical_sql = sizeof($statistical_sql);
            for ($u = 0; $u < $size_statistical_sql; $u++)
               $db->sql_query($statistical_sql[$u]);
         page_footer();
            trigger_error($user->lang['QUIZ_NO_TYPE_SUBMIT']);
   $quiz_id = request_var('q', 0); // get the ID for this quiz being played
   page_header(get_quiz_title($quiz_id));
   $current_progressive = find_current_live_progress_id($quiz_id, 1);
   if ($current_progressive > 0)
      $sql = "SELECT quiz_progress_saved, quiz_progress_time, quiz_progress_stop_time, quiz_time_used
            WHERE quiz_progress_id = $current_progressive";
      $progress_saved = $row['quiz_progress_saved'];
      // Stop people from refreshing the timelimits, etc.
      if    ($config['quiz_time_limit_per_question'] != 0 &&
         (($row['quiz_time_used'] >= (find_number_of_questions_in_quiz($quiz_id) * $config['quiz_time_limit_per_question']))) ||
         ($row['quiz_time_used'] > 0 && $row['quiz_progress_stop_time'] == 0))
      //if( $config['quiz_time_limit_per_question'] &&
      //   ($row['quiz_time_used'] > 0 && $row['quiz_progress_stop_time'] == 0) || () )
      //$progress_time_used = $row['quiz_progress_stop_time'] - $row['quiz_progress_time'];
      $progress_time_used = $row['quiz_time_used'];
      if ($progress_time_used < 0)
         $progress_time_used = 0;
      $questions_saved = explode(';/\;/\;/\;', $progress_saved);
      $questions_saved_size = sizeof($questions_saved);
      $saved_information = array();
      for ($w = 0; $w < $questions_saved_size; $w++)
         $question_given_answer = explode(':/\:/\:/\:', $questions_saved[$w]);
         $saved_information[$w]['question_number'] = intval($question_given_answer[0]);
         $saved_information[$w]['given_answer'] = ( isset($question_given_answer[1]) ) ? $question_given_answer[1] : '';
   $progress_array = array(
        'quiz_player_id'         => $user->data['user_id'],
         'quiz_progress_time'      => time(),
      'quiz_id'               => $quiz_id,
      'quiz_progress_saved'       => '',
      'quiz_time_used'         => 1,
      'quiz_in_progress'         => 1,
   // Enter the data into the progressive data, important to know later on if a user has paused
   // a quiz and wants to resume. Also helpful for admins with time limits enabled.
   $progress_sql = 'INSERT INTO ' . QUIZ_PROGRESSIVE_TABLE . '
               ' . $db->sql_build_array('INSERT', $progress_array);
   $db->sql_query($progress_sql);
   // Get the questions and loop the loop
   $sql = 'SELECT * FROM ' . QUIZ_QUESTIONS_TABLE . '
         WHERE quiz_related_id = ' . $quiz_id . '
         ORDER BY quiz_question_id ASC';
   $quiz_answers_list = array();
   $quiz_answer_row_id = array();
   $question_count = 0;
   $question_formatted = ''; // reset values to avoid a continual build-up of options
   $answer_select_output = '';
      $quiz_question_id = $row['quiz_question_id']; // This is needed to match to results from the data table
      $answer_sql = 'SELECT * FROM ' . QUIZ_DATA_TABLE . '
                  WHERE quiz_question_id = ' . $quiz_question_id;
      $mc_answer_result = $db->sql_query($answer_sql);
      $a = 0;
      while ($answer_row = $db->sql_fetchrow($mc_answer_result))
         $answer_formatted = generate_text_for_display($answer_row['quiz_answer'], $answer_row['quiz_uid'], $answer_row['quiz_bitfield'], $answer_row['quiz_options']);
         $quiz_answers_list[$quiz_question_id][$a] = $answer_formatted;
         $quiz_answer_row_id[$quiz_question_id][$a] = $answer_row['quiz_data_id'];
         $a++;
   $sizeof_mc_array = sizeof($quiz_answer_row_id[$quiz_question_id]);
      if ($sizeof_mc_array > 1)
         $answer_select_output = ''; // The input fields that are shown to the user
         for ($i = 0; $i < $sizeof_mc_array; $i++)
         $checked_input = '';
            // If we are grabbing saved answers
               if (is_numeric($saved_information[$question_count]['given_answer']))
               $checked_input = (intval($saved_information[$question_count]['given_answer']) == intval($quiz_answers_list[$quiz_question_id][$i])) ? 'checked="checked"' : '';
               $checked_input = (utf8_case_fold_nfc($saved_information[$question_count]['given_answer']) == utf8_case_fold_nfc($quiz_answers_list[$quiz_question_id][$i])) ? 'checked="checked"' : '';
            // $answer_select_output .= '<input type="radio" name="question' . $quiz_question_id . '" value="' . $quiz_answer_row_id[$quiz_question_id][$i] . '" ' . $checked_input . ' /> ' . $quiz_answers_list[$quiz_question_id][$i] . '<br />';
            // thanks to mtrs for pointing out the label miss
            $answer_select_output .= '<input type="radio" id="' . $quiz_question_id . $i . '" name="question' . $quiz_question_id . '" value="' . $quiz_answer_row_id[$quiz_question_id][$i] . '" ' . $checked_input . ' /> <label for="' . $quiz_question_id . $i . '">' . $quiz_answers_list[$quiz_question_id][$i] . '</label><br />';
      $value_input = '';
         $value_input = $saved_information[$question_count]['given_answer'];
         @$use_offset_answer = ($quiz_answers_list[$quiz_question_id][$i] != '') ? $quiz_answers_list[$quiz_question_id][$i] : '';
         $answer_select_output .= '<input type="text" name="question' . $quiz_question_id . '" value="' . $value_input . '" /> ' . $use_offset_answer . '<br />';
      $template->assign_block_vars('play_row', array(
      'ANSWER'         => $answer_select_output,
   $question_count++;
   // Time limits stuff
   // Javascript from http://www.java-scripts.net/javascripts/Countdown-Timer.phtml (thanks to author Thomas).
   if ($config['quiz_time_limit_per_question'] > 0)
      if ( isset($progress_time_used) && isset($progress_saved) )
      // Reset the start time - we have already noted the time already used
                  SET quiz_time_used = " . $progress_time_used . ",
                  quiz_progress_time = " . time() . ",
                  quiz_progress_stop_time = 0
                  WHERE quiz_progress_id = " . $current_progressive);
      $total_time_allowed = ( isset($progress_time_used) ) ? (($config['quiz_time_limit_per_question'] * $question_count) - $progress_time_used) : $config['quiz_time_limit_per_question'] * $question_count; // time (seconds) allowed to complete the entire quiz
         'S_SUBMIT_QUIZ_ACTION'         => append_sid("{$phpbb_root_path}quiz.$phpEx", 'mode=play&amp;action=submit'),
         'TIME_LIMITS_ENABLED'         => (isset($total_time_allowed)) ? true : false,
         'TIME_ALLOWED'               => (isset($total_time_allowed)) ? $total_time_allowed : 0,
         'SAVE_ENABLED'               => ($config['quiz_save_enabled'] == '1') ? true : false,
         'body' => 'quiz_play_body.html')
   if ($mode == 'stats')
   page_header($user->lang['QUIZ_STATISTICS']);
   // view statistics
   $stats = new quiz_stats;
   $stats->best_results();
   $stats->most_played();
   $stats->most_correct_answers();
   // $stats->high_percentage_correct_answers();
         'body' => 'quiz_statistics_body.html')
   page_footer();
   else if (!$mode)
   // index and categories
      if( $category )
      // list quizzes in a certain category
      $category_title = get_category_name($category);
      page_header($category_title);
      $sql    = "SELECT * FROM " . QUIZ_TABLE . "
               WHERE quiz_category = $category
               ORDER BY quiz_date DESC";
            $user_info = "SELECT username, user_colour
                       FROM " . USERS_TABLE . "
                       WHERE user_id = " . $row['quiz_author'];
            $user_info_result = $db->sql_query($user_info);
            $user_info_row = $db->sql_fetchrow($user_info_result);
            $db->sql_freeresult($user_info_result);
            // See if the quiz is saved
            $find_if_saved_quiz = false;
            if( $config['quiz_save_enabled'] == 1 )
               $saved_sql = "SELECT quiz_progress_id FROM " . QUIZ_PROGRESSIVE_TABLE . "
                           WHERE quiz_player_id = " . $user->data['user_id'] . "
                           AND quiz_in_progress = 1
                           AND quiz_id = " . $row['quiz_id'];
               $saved_result = $db->sql_query($saved_sql);
               $find_if_saved_quiz = ($db->sql_fetchfield('quiz_progress_id') > 0) ? true : false;
            // See if already played
            $already_played = "SELECT COUNT(stats_id) AS countstats FROM " . QUIZ_STATISTICS_OVERVIEW_TABLE . "
                           WHERE quiz_id = " . $row['quiz_id'];
            $already_played_sql = $db->sql_query($already_played);
            $quiz_is_already_played = ($db->sql_fetchfield('countstats') > 0) ? true : false;
            // is the quiz new? posted since last login
            $is_quiz_new_login = ($user->data['user_lastvisit'] < $row['quiz_date']) ? $user->img('icon_topic_newest', 'VIEW_NEWEST_POST') . ' ' : '';
            $template->assign_block_vars('quiz_row', array(
            'QUIZ_LINK'            => append_sid("{$phpbb_root_path}quiz.$phpEx", 'mode=play&amp;q=' . $row['quiz_id']),
            'QUIZ_NAME'            => $row['quiz_name'],
            'QUIZ_IN_PROGRESS'      => $find_if_saved_quiz,
            'QUIZ_NEW'            => $is_quiz_new_login,
            'QUIZ_ALREADY_PLAYED'   => $quiz_is_already_played,
            'QUIZ_AUTHOR'         => get_username_string('full', $row['quiz_author'], $user_info_row['username'], $user_info_row['user_colour']),
            'QUIZ_DATE'            => $user->format_date($row['quiz_date']),
            'QUIZ_VIEWS'         => ($row['quiz_views'] == 1) ? sprintf($user->lang['NUMBER_OF_QUIZ_VIEWS_SINGLE'], $row['quiz_views']) : sprintf($user->lang['NUMBER_OF_QUIZ_VIEWS_PLURAL'], $row['quiz_views']),
         'U_NEW_QUIZ'         => append_sid("{$phpbb_root_path}quiz.$phpEx", 'mode=submit'),
         'U_STATS'             => append_sid("{$phpbb_root_path}quiz.$phpEx", 'mode=stats'),
         'U_CP'               => append_sid("{$phpbb_root_path}quiz_cp.$phpEx"),
         'CATEGORY_VIEW'         => true,
         'CAN_ACCESS_CP'         => ((intval($config['quiz_user_edit_own_quiz']) == 1) || $auth->acl_get('a_')) ? true : false,
         'CATEGORY_VIEW_NAME'    => $category_title,
         'body' => 'quiz_body.html')
      page_footer();
      page_header($user->lang['QUIZ']);
      $sql = "SELECT * FROM " . QUIZ_CATEGORY_TABLE . "
            ORDER BY quiz_category_name ASC";
            $quiz_category_id       = $row['quiz_category_id'];
            $quiz_category_name    = $row['quiz_category_name'];
            $quiz_category_desc    = $row['quiz_category_description'];
            $quiz_category_password   = ($row['quiz_category_password']) ? $user->lang['QUIZ_PASSWORD_PROTECTED_CAT'] : false;
            $quiz_category_link      = append_sid("{$phpbb_root_path}quiz.$phpEx", 'category='.$quiz_category_id);
            $quiz_count_quiz_num   = find_number_of_quiz_in_category($quiz_category_id);
            $template->assign_block_vars('category_row', array(
            'CAT_LINK'            => $quiz_category_link,
            'CAT_NAME'            => $quiz_category_name,
            'CAT_DESC'            => $quiz_category_desc,
            'CAT_PSWD'            => $quiz_category_password,
            'CAT_NUMBER_QUIZZES'   => ($quiz_count_quiz_num == 1) ? sprintf($user->lang['NUMBER_OF_QUIZ_INDEX_SINGLE'], $quiz_count_quiz_num) : sprintf($user->lang['NUMBER_OF_QUIZ_INDEX_PLURAL'], $quiz_count_quiz_num),
         'U_QUIZ_INTRODUCTION_VALID'   => (strlen($config['quiz_index_introduction']) > 0) ? true : false,
         'U_QUIZ_INTRODUCTION_TEXT'   => $config['quiz_index_introduction'],
      page_footer();
page_footer();
control_quiz.php:
// control_quiz.php
   if( !$auth->acl_get('a_') )
      die('No access');
      if( $_GET['mode'] == 'deactivate' )
         $deactivate_id = (int) $_GET['id'];
         $sql = "UPDATE " . QUIZ_TABLE . " SET quiz_deactivate = 1
               WHERE quiz_id = $deactivate_id";
         die('Quiz id ' . $deactivate_id . ' has been deactivated');
      if( $_GET['mode'] == 'activate' )
         $activate_id = (int) $_GET['id'];
         $sql = "UPDATE " . QUIZ_TABLE . " SET quiz_deactivate = 0
               WHERE quiz_id = $activate_id";
         die('Quiz id ' . $activate_id . ' has been activated');
      if( $_GET['mode'] == 'enter_answers' )
         if( $_GET['a'] == 'submit' )
            $question_id_hidden = $_POST['questions'];
            $question_id_set = explode(',', $question_id_hidden);
            $question_id_set_count = sizeof($question_id_set) - 1;
            $users = array();
            $users_information = array();
            $users_names = array();
            for($i = 0; $i < $question_id_set_count; $i++ )
                     WHERE quiz_question_id = ' . $question_id_set[$i] . '
                  $user_sql = 'SELECT username FROM ' . USERS_TABLE . '
                            WHERE user_id = ' . $row['quiz_player'];
                  $user_result = $db->sql_query($user_sql);
                  $user_name_fetch = $db->sql_fetchfield('username');
                  $db->sql_freeresult($user_result);
                  $users_names[$row['quiz_player']] = $user_name_fetch;
                  $is_correct = 0;
                  $is_incorrect = 0;
                  if( $row['quiz_answer'] == $_POST['question' . $question_id_set[$i]] )
                     // echo 'User <strong>' . $user_name_fetch . '</strong> answered question <strong>' . $question_id_set[$i] . '</strong> CORRECTLY<br />';
                     $users_information[$row['quiz_player']]['quiz_correct']++;
                     $users_information[$row['quiz_player']]['quiz_id'] = $row['quiz_id'];
                     $users_information[$row['quiz_player']]['info'] = 'Question ' . $question_id_set[$i] . ' correct';
                     // echo 'User <strong>' . $user_name_fetch . '</strong> answered question <strong>' . $question_id_set[$i] . '</strong> INCORRECTLY. They entered the answer <strong>' . $row['quiz_answer'] . '</strong>.<br />';
                     $users_information[$row['quiz_player']]['quiz_incorrect']++;
                     $users_information[$row['quiz_player']]['info'] = 'Question ' . $question_id_set[$i] . ' incorrect (' . $row['quiz_answer'] . ')';
            /* for( $j = 0, $j_count = sizeof($users); $j < $j_count; $j++ )
               echo 'Username: ' . $users_names[$users[$j]] . '<br />';
               echo '-- Correct: ' .  $users_information[$users[$j]]['quiz_correct'] . '<br />';
               echo '-- Incorrect: ' .  $users_information[$users[$j]]['quiz_incorrect'] . '<br />';
               echo '-- Quiz ID: ' .  $users_information[$users[$j]]['quiz_id'] . '<br />';
            $counter = 0;
         $highest_correct = 0;
         $output_array = array();
            foreach($users_names as $key => $val)
            $quiz_id_key = $users_information[$key]['quiz_id'];
               if( $counter == 0 )
                  $counter++;
                  echo 'QUIZ ID: ' . $quiz_id_key . ' QUIZ NAME: ' . get_quiz_title($quiz_id_key) . '<br />';
               // $key is the user_id, $val is the username
               $correct_answers = ($users_information[$key]['quiz_correct']) ? $users_information[$key]['quiz_correct'] : 0;
               $incorrect_answers = ($users_information[$key]['quiz_incorrect']) ? $users_information[$key]['quiz_incorrect'] : 0;
               $output_array[$correct_answers][] = $val . ' (correct: ' .  $correct_answers . ', incorrect: ' .  $incorrect_answers . ')<br />';
               $highest_correct = ($correct_answers > $highest_correct) ? $correct_answers : $highest_correct;
               $statistical_overview_setup[] = array(
                  'quiz_id'         => (int) $quiz_id_key,
                    'quiz_correct'      => (int) $correct_answers,
                    'quiz_incorrect'   => (int) $incorrect_answers,
                  'user_id'         => (int) $key,
                  'quiz_time'         => (int) 0,
         for( $m = $highest_correct; $m >= 0; $m-- )
               $size_current_ca = sizeof($output_array[$m]);
               if( $size_current_ca > 0 )
                  for( $n = 0; $n < $size_current_ca; $n++ )
                     echo $output_array[$m][$n];
            $db->sql_multi_insert(QUIZ_STATISTICS_OVERVIEW_TABLE, $statistical_overview_setup);
            echo 'SQL Query entered';
            die();
         $quiz_id = (int) $_GET['id'];
               WHERE quiz_related_id = ' . $quiz_id;
         echo '<form action="control_quiz.php?mode=enter_answers&id=' . $quiz_id . '&a=submit" method="post">';
         $question_id_hidden = '';
            $question_id_hidden .= $row['quiz_question_id'] . ',';
            echo '<strong>Question: ' . $row['quiz_question'] . '</strong><br />';
            // echo 'Correct answer: <input type="text" name="question' . $row['quiz_question_id'] . '" />';
            echo 'Correct answer:';
            $ans = 'SELECT quiz_answer FROM ' . QUIZ_DATA_TABLE . '
                  WHERE quiz_question_id = ' . $row['quiz_question_id'];
            $ans_res = $db->sql_query($ans);
            while( $ans_row = $db->sql_fetchrow($ans_res) )
               echo '<input type="radio" value="' . $ans_row['quiz_answer'] . '" name="question' . $row['quiz_question_id'] . '" /> ' . $ans_row['quiz_answer'] . '&nbsp;&nbsp;&nbsp;';
            echo '<br /><br />';
         echo '<input type="hidden" value="' . $question_id_hidden . '" name="questions" />';
         echo '<input type="submit" value="Submit" name="submit" />';
         echo '</form>';
         die(); // new
         echo 'Mode types:<br />
            <strong>control_quiz.php?mode=deactivate&id=XXX</strong><br />
            <strong>control_quiz.php?mode=activate&id=XXX</strong><br />
            <strong>control_quiz.php?mode=enter_answers&id=XXX</strong>';
         die();
Any ideas?
subvertbeats
Postby battye » Mon Feb 01, 2010 1:51 pm
Have a look in the phpbb_quiz_statistics table and make sure there is:
a) a quiz_player column
b) all rows have a quiz_player entry
Postby subvertbeats » Mon Feb 01, 2010 2:13 pm
Hi battye
Yep, column exists and is populated throughout
subvertbeats
Postby battye » Tue Feb 02, 2010 3:22 am
FIND in control_quiz.php
AFTER ADD
                 echo '>>'. $row['quiz_player'] . '<br />';
And post the output in your next reply :)
Postby subvertbeats » Tue Feb 02, 2010 9:00 am
thanks battye... I get no output there:
Warning: Cannot modify header information - headers already sent by (output started at /home/mmadent/public_html/foru/control_quiz.php:64) in /home/mmadent/public_html/foru/includes/functions.php on line 3543
subvertbeats
Postby battye » Tue Feb 02, 2010 12:32 pm
I suspect you might be trying to enter answers for a quiz that doesn't exist. Double check the id you used is correct.
PreviousNext
Return to Web Design
