[BETA 4] Calendar Alerts MOD v0.0.4
Re: [BETA 3] Calendar Alerts MOD v0.0.3
Postby battye » Sat Mar 20, 2010 4:51 pm
Thanks plasmino, I've updated the first post :D
Postby pluto » Fri Jul 16, 2010 8:19 pm
Hello,
When I want to cancel a deletion warning, I get this error:
Général error
template->_tpl_load_file(): File ./styles/acidtech/template/.html does not exist or is empty
Thank you to you.
pluto
Postby Marije » Wed Jul 28, 2010 8:44 pm
Hi, great mod!
Perfect for me, who always forgets everything haha
I have 2 questions
Is there a dutch translation?
And can i edit it somehow to make it only for the admin, not the other users?
Marije
Postby Marije » Mon Aug 02, 2010 6:27 pm
Does anyone know these anwers?
Marije
Postby battye » Tue Aug 03, 2010 10:18 am
Hi, sorry for the delay in replying. I don't think there is Dutch, every translation I know of is in this post: viewtopic.php?f=63&t=4746
And when you say make it only for the admin, do you mean you want alerts to appear only to admins or you want both the "add alerts" page in the UCP and the alerts on the index to only appear to admins? Just let me know which it is - it is a fairly easy change to implement and I will tell you which code you will need to edit :)
Thanks for registering at CMX Marije, welcome to the forum :)
Postby Marije » Tue Aug 03, 2010 11:42 am
Thanx for the reply
I want it to be only for admin, both the page in UCP to add an alert, and to see the alert.
Marije
Postby pluto » Wed Aug 04, 2010 11:56 am
pluto wrote:Hello,
Général error
Thank you to you.
Hello,
Person for the solution ?
Thank you very much.
pluto
Postby battye » Wed Aug 04, 2010 2:25 pm
Hi pluto, have you uploaded ucp_alerts.html to styles/acidtech/template/ :?:
Postby pluto » Wed Aug 04, 2010 2:40 pm
Yes, this file "ucp_alerts.html" is indeed in: styles/acidtech/template/
Thank you.
pluto
Postby battye » Wed Aug 04, 2010 2:42 pm
What about confirm_body.html?
Postby pluto » Wed Aug 04, 2010 2:45 pm
confirm_body.html is OK also, It's just the cancellation :|
Otherwise the mod to work perfectly 8)
Edit: I did a test on your forum and when I delete an alert and click cancel I get a blank page.
pluto
Postby battye » Thu Aug 05, 2010 5:00 am
Try this:
open ucp_alerts.php and find:
         if (confirm_box(true))
            $sql = "DELETE FROM " . ALERTS_TABLE . "
                  WHERE alert_id = " . request_var('delete', 0) . "
                  AND user_id = " . (int) $user->data['user_id'];
            $db->sql_query($sql);
            // Clear the cache
            $cache->destroy('sql', ALERTS_TABLE);
            trigger_error( sprintf($user->lang['UCP_ALERTS_DELETE_SUCCESS'], "<a href='" . append_sid($this->u_action) . "'>", "</a>") );
After add:
trigger_error('Test');
Now try it, you should get the message 'Test' (if this works then I will give you the redirect code :))
Postby pluto » Thu Aug 05, 2010 8:28 pm
Indeed, when I click the little X to delete the word "test" appears :)
Thank you.
pluto
Postby battye » Fri Aug 06, 2010 3:36 pm
Now replace the line:
With
redirect(append_sid("{$phpbb_root_path}ucp.$phpEx""i=alerts&amp;mode=alerts"));
Does that fix it? :)
Postby pluto » Fri Aug 06, 2010 4:07 pm
No sorry, nothing happens, this has no effect :|
Note: I do not have the phrase "Are you sure you want to delete this alert?"
pluto
PreviousNext
Return to Web Design
