Re: [ALPHA 1] Ultimate Quiz MOD v2.1.0 Progress
Postby Clenzowen » Fri Feb 18, 2011 4:43 pm
thank you very much.
Clenzowen
Postby Abera » Fri Feb 18, 2011 5:12 pm
I think I messed mine up. This came up:
Creating table phpbb_quiz...
Creating table phpbb_quiz_questions...
Creating table phpbb_quiz_statistics...
Installation is finished with no errors.
Then this:
General Error
SQL ERROR [ mysqli ]
Table 'zz_mk1.quiz_categories_table' doesn't exist [1146]
SQL
SELECT * FROM QUIZ_CATEGORIES_TABLE ORDER BY quiz_category_name ASC
BACKTRACE
FILE: includes/db/mysqli.php
LINE: 163
CALL: dbal->sql_error()
FILE: includes/acp/acp_quiz.php
LINE: 172
CALL: dbal_mysqli->sql_query()
FILE: includes/functions_module.php
LINE: 507
CALL: acp_quiz->main()
FILE: adm/index.php
LINE: 74
CALL: p_master->load_active()
Abera
Postby battye » Fri Feb 18, 2011 5:16 pm
Abera, which page were you on when that error occurred? From the error, I assume the ACP?
Did you definitely update the files (in particular /includes/quiz/quiz.php - which is where QUIZ_CATEGORIES_TABLE is defined)?
Also, did you accidentally run quiz_installer.php from v2.1.0 instead of the one included in v2.1.1? Because in your message above it doesn't say "Creating table phpbb_quiz_categories..." :)
Postby Abera » Fri Feb 18, 2011 5:25 pm
battye wrote:Abera, which page were you on when that error occurred? From the error, I assume the ACP?
I updated all of the files and ran the v2.1.1 installer. Some how I tend to think it was my fault as always. Looks like I'll have to start all over again.
Thanks and will get back.
Abera
Postby battye » Fri Feb 18, 2011 5:37 pm
Make sure that
define('QUIZ_CATEGORIES_TABLE', $table_prefix . 'quiz_categories');
Is on the second last line of includes/quiz/quiz.php - if it is, then that file is okay and the problem lies elsewhere.
Edit: Something I just thought of... did you run quiz_installer.php before you uploaded the modified files?
Postby Abera » Fri Feb 18, 2011 6:02 pm
battye wrote:Make sure that
The includes/quiz/quiz.php is fine and I completely started over. All of the edits for the MOD and uploaded all of the new files. Then ran the install. Now it shows:
General Error
Table 'phpbb_quiz' already exists [1050]
SQL
CREATE TABLE phpbb_quiz ( quiz_id INT(5) NOT NULL AUTO_INCREMENT PRIMARY KEY, quiz_name VARCHAR(255) NOT NULL, quiz_time INT(20) NOT NULL, quiz_category INT(5) NOT NULL, user_id INT(8) NOT NULL, username VARCHAR(255) NOT NULL, user_colour VARCHAR(10) NOT NULL )
BACKTRACE
LINE: 163
FILE: quiz_installer.php
LINE: 74
Sorry for all of the hassle. #-o
Thanks
PS
I did the MOD file edits over.
Abera
Postby Abera » Fri Feb 18, 2011 7:28 pm
Here is all that I'm seeing:
My quiz.php
db tables
Cats page
After sub
Thanks
Abera
Postby quahappy » Fri Feb 18, 2011 7:34 pm
Post contents removed to avoid confusion with my new post below.
quahappy
Happy, not Quappy
Happy, not Quappy
Postby quahappy » Fri Feb 18, 2011 9:54 pm
There is a missing comma in the quiz_installer.php (211 Alpha 2) file which will cause a syntax error during installation. Before running this file, you must edit quiz_installer.php and add a comma at end of following line:
Incorrect:
('qc_cash_column', 'user_points', 1)
Correct:
('qc_cash_column', 'user_points', 1),
Install will then work.
IF ACP Quiz module doesn't show; go to ACP > System (tab) > Module management : Administration Control Panel. To right of Quiz module is "Enable". Click on this. You may also need to Purge the cache as well: ACP > General (tab) : Purge the cache.
As battye mentioned, immediately create a new Category within ACP > UQM before proceeding any further (i.e. create quiz).
New issue:
ACP > UQM > Create category. Entered a name then on Submit. Received this error:
General Error
Incorrect integer value: 'General' for column 'quiz_category_name' at row 1 [1366]
SQL
INSERT INTO phpbb_quiz_categories (quiz_category_name) VALUES ('General')
BACKTRACE
LINE: 163
LINE: 86
LINE: 507
FILE: adm/index.php
LINE: 74
Easily solved. I've altered (via phpMyAdmin):
quiz_category_namae INT(5) NOT NULL
to:
quiz_category_name VARCHAR(255) NOT NULL
Couple of questions although it's common sense from the "controller" really:
Will ACP > UQM be foolproof? Examples:
The maximum number of questions field MUST be greater than the minimum number of questions field. ATM, anything can be entered. Although on testing (create a Quiz) it didn't cause any conflict.
Maximum multiple choices - d/b accepts zero. Think this needs to be at least a minimum of Two. (true/false for example).
I don't have any form of Cash/Points MOD so can't comment on this section.
quahappy
Happy, not Quappy
Happy, not Quappy
Postby Clenzowen » Fri Feb 18, 2011 10:05 pm
good evening
when I want to start installing the update I get this error message.
Erreur générale
SQL ERROR [ mysql4 ]
Table 'phpbb3_quiz_categories' already exists [1050]
SQL
CREATE TABLE phpbb3_quiz_categories ( quiz_category_id INT(5) NOT NULL AUTO_INCREMENT PRIMARY KEY , quiz_category_name INT(5) NOT NULL )
BACKTRACE
FILE: includes/db/mysql.php
LINE: 175
LINE: 48
CALL: dbal_mysql->sql_query()
and
Warning: Cannot modify header information - headers already sent by (output started at /home/forumsfa/public_html/personnel/gratuits/arcades-et-jeux-35/quiz_installer.php:1) in /home/forumsfa/public_html/personnel/gratuits/arcades-et-jeux-35/includes/functions.php on line 2678
can u help me please
Clenzowen
Postby Abera » Sat Feb 19, 2011 12:52 am
quahappy wrote:
New issue:
to:
Worked great for me.
Thanks
Abera
Postby Abera » Sat Feb 19, 2011 12:56 am
All is working fine for me, but I'd like to change a color.
Color change.
Thank you all for the help.
Abera
Postby battye » Sat Feb 19, 2011 4:44 am
Thanks for picking those things up quahappy :cry: I have made and uploaded the changes, if anyone wants the updated package (only quiz_installer.php has changed).
And a good point about ACP validity checking - will add it to the list for 2.1.2 :)
Clenzowen - do you have phpMyAdmin? As quahappy mentioned, there was a mistake in the categories table query which made the category name a number instead of a string (words).
Abera, the colour is the same used as in polls.
Re: [ALPHA 2] Ultimate Quiz MOD v2.1.1 Progress
Postby Clenzowen » Sat Feb 19, 2011 6:37 am
Hello
how are you?
yes I have my php admin, what should I do to repair the error because of the sudden we can no longer play the quiz on the forum
Clenzowen
Postby battye » Sat Feb 19, 2011 7:05 am
In phpMyAdmin find the phpbb_quiz_categories table, click "Structure", then find "quiz_category_name". Edit that row by clicking the small pencil button. Change "Type" to VARCHAR and "Length/values" to 255 and submit the changes :)
PreviousNext
Return to Web Design
