Page 21 of 32
Re: [BETA 4] Ultimate Quiz MOD v2.0.0 Progress
Posted: Wed Oct 27, 2010 4:33 pm
Cable is back online now, I'll try and answer both of these posts tomorrow. Thanks for your patience
Posted: Thu Oct 28, 2010 1:56 pm
joschka wrote:many Thanks battye!!
that was ist!
have you a any idea for this one??
You want to show all results as numerics instead of percentage, yes? I can't help with this. Battye (UQM MOD developer) may be able to assist with this.
at least one value so that a winner can be determined
have a nice day
joschka, I guess you mean total correct answers? If so for both lines instead of:
'PERCENTAGE' => (($row['quiz_incorrect']+$row['quiz_correct'])<1) ? 0 : number_format((100*$row['sum_correct'])/($row['sum_incorrect']+$row['sum_correct']), 0) . '%',
Put:
'PERCENTAGE' => $row['quiz_correct'],
arsalan, what do you mean by prediction MOD? Yes it can be used like that now to a certain degree, but it depends on what exactly you need. Can you elaborate? Thanks
Posted: Fri Oct 29, 2010 1:41 am
by arsalan
Currently you have to submit answer when you submit question.
I want to ask can we change or edit answer after submission of question?
Posted: Thu Nov 11, 2010 1:01 pm
by IronDogg
Hi battye,
I was just curious how development of this mod is coming along, and when the next release might be made available?
Posted: Tue Nov 16, 2010 6:38 am
arsalan: yes you are able to edit questions and answers after they are submitted in the Quiz CP (if I recall!)
IronDogg, the last 6 months have been very busy in real life! It's just a case of getting back to UQM whenever some time presents itself! I do have quite a few ideas, including some mentioned by members of the community, which I am keen to implement
Posted: Tue Dec 21, 2010 3:19 pm
by sotis
pcmander wrote:when i complete a quiz as a user, it shows this:
This quiz was neither saved nor submitted
This happened with foreign language characters . The problem I found was in quiz.php
$save_type = request_var('submit', '');
I changed it a little bit and it works now
$save_type = utf8_normalize_nfc(request_var('submit', '', true));
There was one more problem with input questions and I changed one more line:
$given_user_input = request_var('question' . $give_question_id, ''); // raw input
to
$given_user_input = utf8_normalize_nfc(request_var('question' . $give_question_id, '', true)); // raw input
Posted: Sun Feb 06, 2011 3:18 pm
Recently when I've found a bit of time I've worked away at rewriting UQM. The previous version was getting too large and unwieldy from a code perspective, so I'm trying to use a bit more object orientation this time around. I've got it all set up on another computer at the moment so these are the only screenshots I've got handy:
I'll post some more up soon with a bit more information about the new version
Posted: Tue Feb 08, 2011 8:16 am
by quahappy
Give us Beta Testers a nudge if and when you require our assistance battye.
Posted: Thu Feb 10, 2011 12:33 pm
Posted: Thu Feb 10, 2011 2:23 pm
by quahappy
Looking well good battye! Especially like the added text colours and boldness of questions.
Posted: Fri Feb 11, 2011 6:02 pm
Thanks quahappy, here is the latest screenshot. I spent quite a bit of time today finishing up the statistics modules. I know in the past "surveys" were a big feature request so I have included them on the stats page:
I realise you could ascertain the correct answers from looking at that page, so I have added a restriction that only administrators, the quiz author or anyone that has played the quiz can see the page. And in case anyone still thinks that is not restricted enough, it is pretty easy to disable any of the statistics modules
Re: [ALPHA 1] Ultimate Quiz MOD v2.1.0 Progress
Posted: Sun Feb 13, 2011 9:55 am
by plasmino
ok have install ALPHA 1
error debug in quiz page ^_^
[phpBB Debug] PHP Notice: in file /quiz.php on line 515: Undefined variable: auth_params
Posted: Sun Feb 13, 2011 10:14 am
That's strange, I have debug mode on as well but I didn't get that error. Hopefully there are not any other undefined variables that went by unnoticed
Having said that I can see why the error is occurring. $auth_params is declared and initialised inside the while loop
Open quiz.php and FIND
'L_STATS_UPPER' => strtoupper($user->lang['UQM_STATS_QUIZ']),
'L_SUBMIT_UPPER' => strtoupper($user->lang['UQM_SUBMIT_QUIZ']),
'U_UQM_SUBMIT' => ($quiz_configuration->auth('submit', $auth_params)) ? append_sid("{$phpbb_root_path}quiz.$phpEx", 'mode=submit') : '',
In the third line, see
$auth_params - replace that with
$submit_auth_params
Before the
$template->assign_vars line, put this code:
$submit_auth_params = array(
'administrator' => $auth->acl_get('a_'),
'submit_setting' => $quiz_configuration->value('qc_admin_submit_only'),
'return_value' => true,
Posted: Sun Feb 13, 2011 10:21 am
by plasmino
perfect fix
Posted: Sun Feb 13, 2011 10:36 am
Fantastic
Have you seen any other debug errors yet? I am hoping that the $auth_params error was the only one
