phpBB2 UQM - No Quiz Authors ACP
quahappy
Happy, not Quappy
Happy, not Quappy
Back again for one final time and this topic can be resolved. ;)
I've modified quiz_play_once_addition code to quiz.php as the additional AFTER, ADD below:
                 if( is_numeric($qpo_user_plays[$exp]) && $qpo_user_plays[$exp] == $userdata['user_id'] )
AFTER, ADD
             if( quiz_check_moderative_status($userdata['user_id'], $quiz_id) == ON )
             $message_ctl = sprintf($lang['Quiz_author_cannot_play_give_edit_options'], '<a href="' . append_sid("quiz_cp.$phpEx?mode=edit&q=$quiz_id") . '">', '</a>', '<a href="' . append_sid("quiz_cp.$phpEx?mode=delete&q=$quiz_id") . '">', '</a>', '<a href="' . append_sid("quiz_cp.$phpEx?mode=move&q=$quiz_id") . '">', '</a>');
.... allowed countdown timer to be restarted if browser page was refreshed or browser back selected instead of the "You have already attempted to play this Quiz" message. Basically I've moved the quiz_check_moderative_status function to before $qpo_sql = $db->sql_query("SELECT quiz_user_list....
Anyhow, to save confusion, here's the modified code. Slightly messy but it works. ;)
       // 06-11-08 quiz_play_once_addition
         $message = 'You have already attempted to play this Quiz'  . '<br /><br />' . sprintf($lang['Quiz_click_return_quiz'], '<a href="' . append_sid("quiz.$phpEx") . '">', '</a>');
         $message_ctl =  '<br /><br />' . sprintf($lang['Quiz_author_cannot_play_give_edit_options'], '<a href="' . append_sid("quiz_cp.$phpEx?mode=edit&q=$quiz_id") . '">', '</a>', '<a href="' . append_sid("quiz_cp.$phpEx?mode=delete&q=$quiz_id") . '">', '</a>', '<a href="' . append_sid("quiz_cp.$phpEx?mode=move&q=$quiz_id") . '">', '</a>');
       $qpo_sql = $db->sql_query("SELECT quiz_user_list FROM " . QUIZ_GENERAL_TABLE . " WHERE quiz_id = $quiz_id");
       $qpo_row = $db->sql_fetchrow($qpo_sql);
       $qpo_user_plays = explode(',', $qpo_row['quiz_user_list']);
          for( $exp = 0; $exp < count($qpo_user_plays); $exp++ )
             message_die(GENERAL_MESSAGE, $message . $message_ctl);
       $qpo_addition_list = $qpo_row['quiz_user_list'] . ',' . $userdata['user_id'];
       $db->sql_query("UPDATE " . QUIZ_GENERAL_TABLE . " SET quiz_user_list = '" . $qpo_addition_list . "' WHERE quiz_id = $quiz_id");
       // -- end qpo addition
The above also includes option (link) for the user to return to Quiz Index page.
Also, in an ideal situation, the You have already attempted to play this Quiz shouldn't be true if it's a quiz created by the quiz author as on first "play" the You cannot play quizzes which you have submitted! is correctly displayed (along with moderator controls). Of course, thereafter, the quiz_user_list gets updated meaning that subsequent selection of a Quiz created by the Quiz Author results in You have already attempted to play this Quiz (again, with Moderator controls).
Like I've said elsewhere, I'm not an expert on php and still getting to grips with it so forgive me if it's not quite the right way to do what I've done.
:D
quahappy
Happy, not Quappy
Happy, not Quappy
EDIT: I wasn't going to be beaten with Information messages (see "ideal situation..." above) so here's the code again that displays all correct Information messages according to moderator status, quiz already played, etc:
         $message = 'You have already attempted to play this Quiz' .'<br />';
         $message = $lang['Quiz_author_cannot_play'] .'<br />' . sprintf($lang['Quiz_author_cannot_play_give_edit_options'], '<a href="' . append_sid("quiz_cp.$phpEx?mode=edit&q=$quiz_id") . '">', '</a>', '<a href="' . append_sid("quiz_cp.$phpEx?mode=delete&q=$quiz_id") . '">', '</a>', '<a href="' . append_sid("quiz_cp.$phpEx?mode=move&q=$quiz_id") . '">', '</a>') .'<br />';
             message_die(GENERAL_MESSAGE, $message . '<br />' . sprintf($lang['Quiz_click_return_quiz'], '<a href="' . append_sid("quiz.$phpEx") . '">', '</a>'));
quahappy
Happy, not Quappy
Happy, not Quappy
Darn it! Well it worked so far and then, although a Quiz Author had the Moderator Control options (only for OWN quizzes they created), clicking on any one of them (EDIT, DELETE, MOVE) resulted in a "You are not a Quiz Moderator!" message! On checking quiz_cp.php there is no checking for a quiz author (unless I overlooked something) so done this:
OPEN quiz_cp.php
$users = explode(',', $board_config['Quiz_Moderators']);
	for( $o = 0; $o < count($users); $o++ )
		if( $userdata['user_id'] == intval($users[$o]) )
			$quiz_moderator = ON;
AFTER, ADD
// Does Quiz Author have permission to Moderate own Quiz?
	if( $board_config['Quiz_Author_Mod'] == ON )
		$sql = "SELECT quiz_author FROM " . QUIZ_GENERAL_TABLE . " WHERE quiz_id = '$quiz_id'";
			message_die(GENERAL_ERROR, '', 'Could not obtain the user id', __LINE__, __FILE__, $sql);
		if( $row['quiz_id'] == intval($user_id) )
// End Quiz Author check
And in includes/functions_quiz.php:
        if( $row['user_id'] == intval($user_id) )
REPLACE WITH
Got there in the end. :D
quahappy
Happy, not Quappy
Happy, not Quappy
Pleased to say that this MOD (phpBB2) went "live" on 1st January at my site. I have altered quite a bit in terms of style layout, links, etc. Thanks battye for all your help. :D
