Moderative status over authors' own quizzes
In quiz_cp.php
	for( $o = 0; $o < count($users); $o++ )
		if( $userdata['user_id'] == intval($users[$o]) )
			$quiz_moderator = ON;
	if( $quiz_moderator != ON && $userdata['user_level'] != ADMIN )
		message_die(GENERAL_ERROR, $lang['Quiz_cp_not_moderator']);
Firstly, try replacing it with:
echo 'MOD STATUS: ' . $quiz_moderator;
If it says MOD STATS: 1, replace it with this:
	if( $quiz_moderator != ON )
Otherwise, I'll need to look into it some more. It looks like I didn't finish this moderator part too well, but if that's the case I'm surprised it has never been reported before :?
ABTOP
There is nothing showing.
Here's what I get at the very top of the page
MOD STATUS:
Warning: Cannot modify header information - headers already sent by (output started at /home/newrus06/public_html/forum/quiz_cp.php:54) in /home/newrus06/public_html/forum/includes/page_header.php on line 943
Warning: Cannot modify header information - headers already sent by (output started at /home/newrus06/public_html/forum/quiz_cp.php:54) in /home/newrus06/public_html/forum/includes/page_header.php on line 947
Warning: Cannot modify header information - headers already sent by (output started at /home/newrus06/public_html/forum/quiz_cp.php:54) in /home/newrus06/public_html/forum/includes/page_header.php on line 949
It should produce either 1 or 2, right?
Why on earth is it giving me nothing?
Hmm, that is a very good question.
I'm expecting the number 1... I'll have a look back through functions_quiz.php and use that code, that seemed to produce the right number.
Should have a reply for you in a few hours :?
ABTOP
So, do you think there is any hope for me?
What happens if you try using the quiz.php/quiz_cp.php from v1.2.0 out of interest?
DL from http://www.phpbb.com/community/viewtopic.php?t=362280
ABTOP
battye wrote:What happens if you try using the quiz.php/quiz_cp.php from v1.2.0 out of interest?...
1. I don't get the moderator's buttons for my quizzes.
2. if I play somebody else's quiz, I do get the moderator's button, although I'm not a moderator, and when I hit any of those I get "You are not a moderator" error.
I tried adding the line
echo "MOD STATUS: " . $quiz_moderator;
in quiz_cp.php like before and I still get nothing for the status
MOD STATUS:
ABTOP
Have you given up?
Unfortunately I have been quite busy. As soon as I find time for UQM I will make finding a solution to this a priority.
ABTOP
battye wrote:... As soon as I find time for UQM I will make finding a solution to this a priority.
http://youtube.com/watch?v=9mcZdDCOeuE
:oops: :oops: :oops:
As nobody else has ever reported this problem, perhaps it could be part of server configuration? Or maybe not all of the v1.3.3 files have been uploaded fully?
ABTOP
So it should be working even without this correction?
This may be a server configuration. Except it gives me the same problem on my localhost test server as on the main forum. Don't you have a test/development installation?
I have checked the installation many times, but I will install it from the original distribution again.
Hmm, good point.
I used to have this installed about 2 or 3 years ago, I don't remember having any problems.
Could you post quiz_cp.php in this forum (within
 tags though)
Thanks
