phpBBfm
Shaistav
I have a phpbbfm forum and i want to install the mod which IP is only shown to admins... is it the same or different!!
battye check your PMs!!!!!
It should install, but having said that I wouldn't be surprised if it didn't, because the code is so different.
It's worth a shot. Just make sure you have a backup (of the files, I doubt the MOD you are referring to will make database alterations) to restore in case it doesn't work :)
