I want to create an ad place (with same style as prosilver around it)
Just like in this image below:
I do not want to edit it in the header/footer
so all pages get it, only viewforum/viewtopic
Inex page gona have another similar thing in it so
Create an ads to the right side of viewforum/viewtopic
Volunteer Forum Community
Would you be happy with putting it in a table, or do you wish to maintain the tableless CSS which IIRC is in place in proSilver?
Any way is fine, but the closer to original phpBB code the better...battye wrote:Would you be happy with putting it in a table, or do you wish to maintain the tableless CSS which IIRC is in place in proSilver?
Also, i think this mod has "the box code"
http://startrekguide.com/forum/viewtopi ... =84&t=2711
Okay, if you don't mind a table (it will be borderless, so you won't know the difference at a glance) it should be fairly easy.
Would you be able to PM me the contents of these files?
styles/proSilver/templates/viewforum_body.html and styles/proSilver/templates/viewtopic_body.html
Thanks
Thanks
Done
Okay, we'll experiment with viewforum.
Find
BEFORE ADD
BEFORE ADD
Let me know how that goes
Apologies if the layout doesn't work, simply undo the changes if that is the case
Find
<!-- IF S_HAS_SUBFORUM -->
<!-- IF not S_IS_BOT -->
<ul class="linklist">
<li class="rightside"><a href="{U_MARK_FORUMS}">{L_MARK_FORUMS_READ}</a></li>
</ul>
<table border="0">
<tr>
<td>
<!-- IF .topicrow and not S_DISPLAY_ACTIVE -->
<div class="topic-actions">
<!-- IF S_IS_POSTABLE and not S_IS_BOT -->
<div class="buttons">
</td>
<td>####AD CODE HERE####</td>
</tr>
</table>
How did this work out?
One of my HDD has crached at home,
or it is begining to.
So i test this in the comming week when my
home computer is up and running again...
Lycky me that it is one the c: disk with no
importent things on it anymore =P
Ouch, bad luck mate!
Glad to hear there was no important information on your C: drive.
It almost worked, as you can see it dosen't uses the full width then
Instead of
Try
<table border="0">
<tr>
<td>
<table width="100%" border="0">
<tr>
<td>
Yes it seems to work now, i gona test it for a few days with different browsers etc,
and then i tell you the results, and you can publish it as a full RC2 mod at phpbb.com or something
Some changes:
Find:
<!-- BEGIN topicrow -->
Before add:
<tr>
<td VALIGN="TOP">
Find:
<!-- END topicrow -->
After add:
</td>
<td VALIGN="TOP" WIDTH="170" ALIGN="CENTER">
<!-- Banner Start -->
### YOUR BANNER HERE ###
<!-- Banner END -->
</td>
</tr>
</table>
That works greate on the normal viewforum.php
But if you look at the category, it dosen't look so good =/
Like this:
Normal viewforum:
http://www.adminklubben.se/viewforum.php?f=2
Works fine
Looking at the categories:
http://www.adminklubben.se/viewforum.php?f=28
Ads gets under
Is it possibly to exclude the ads to be shown in the categories ?
like:
<!-- if_category_dont_show --> <!-- end if -->
something like all other strange new code bb3 has...
Like this:
Normal viewforum:
Works fine
Ads gets under
like:
