Download Older version?
nic
Hi! I was wondering if anyone can tell me where I can download the Ultimiate Quiz Mod version 0.6.1? I checked out phpbb, but none of the downloads are working there!
I want to install the quiz mod on my forum which uses CH...
Thanks in advance!
Nicole
Hi :)
You don't want 0.6.1, that is so old and out of date it's not funny. (~3 years give or take)
Download v1.3, it is the newest, and the best. It can be obtained from http://www.cmxmods.net/quiz.php
There is no reason why it shouldn't work with CH installed, but if you run into any problems let me know.
nic
I downloaded that version a few days ago, but there were a few lines of code that I wasn't able to find - I'm not anywhere near skilled enough to figure out how to make it work on my own! But I read somewhere that that older version was compatible with CH - so decided to take the safer route!
There were only two places that I had trouble finding the code, and both had to do with case PAGE_FAQ.... Below are the two sections that I wasn't able to find. I am using CH 2.1.6 on PHPBB 2.0.22
I could not find the following code in admin\index.php
#-----[ FIND ]-----------------------------
				case PAGE_FAQ:
					$location = $lang['Viewing_FAQ'];
					$location_url = "index.$phpEx?pane=right";
					break;
I could not find the following code in viewonline.php
				case PAGE_FAQ:
					$location_url = "faq.$phpEx";
					break;
Those edits are not vital. All that does is add a "Viewing Quiz" line to the who is online area, to show when a user is viewing a quiz.
But this is not vital to the MOD's functionality, so you may leave that out :)
nic
Well that is good news! I went ahead and changed/copied all of the files, I'm still getting an error though -- Did I mess up somewhere?
Could not obtain quiz category data
An Error Occurred
DEBUG MODE
SQL Error: 1146 Table 'cwdb.phpbb_quiz_categories' doesn't exist
Line : 1017
File : quiz.php
Sounds like you didn't run quiz_install.php :)
nic
:oops: oops!
I ran the quiz install, and everything appeared to be working! I created 2 'test" quizzes, which seemed to go over well. But, as soon as I created a quiz, I didn't receive any confirmation - just a blank screen.
Also, when going back and attempting to take one of the quizzes, i'm getting a blank screen...
you can test it out on my forum if you'd like to have a look:
http://www.corpswives.com
Log-in: testing
Password: testing
Thank you for taking the time to answer my questions!
Have all of the .tpl files been uploaded to the templates/*/ directory?
If so, what version of PHP (not the phpBB forum version) are you running? (if unsure, it's usually listed in cPanel)
nic
I re-uploaded all of the files this morning -- no go :-(
i searched around in my ACP - I have no clue what version of php i'm using!
Do you have cPanel?
Usually this can be accessed by going to http://www.site.com/cpanel (replacing the "site.com" with your actual/real domain name)
