error after taking a quiz
GaVrA
An Error Occurred
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'WHERE quiz_id = 4' at line 1
Line : 165
File : functions_quiz.php
other quizes work, but for the newest one i had to put max # of questions to 50 so maybe thats a problem? :(
What were you doing at the time of the error?
GaVrA
sitting beside my pc? :)
i was taking a quiz and i finnished it, i clicked submit and then this error came up... :(
GaVrA wrote:sitting beside my pc? :)
Ah alright, if you stand up rather than sit down the error will go away :)
..... :P
Has this ever happened to you before, or does it happen every time you take a quiz? If it happens often, are you sure every table has been created in the database?
GaVrA
it happends only for this new quiz... :(
i enter any other quiz and click submit and it works, but i click in this quiz submit and i get that error.... :(
these quizes that work are Multiple Choice Quiz and the one that doesnt work is Multiple Checkbox Quiz... any more info i need to submit? :)
Don't know what that is, certainly isn't a part of the default package :)
garmabeaneth
Dancing Queen
Dancing Queen
next time put your right hand in and shake it about, do the hokey pokey and turn yourself around. that should work :D
(¯`·._.·[GUEST 601]·._.·´¯)
smile you're on candid camera Image
GaVrA
Unable to delete quiz data
DEBUG MODE
DELETE FROM WHERE quiz_id = 4
Line : 343
File : quiz_cp.php
now i cant delet taht god damn quiz!!!
GaVrA
ups! i can, but i got this error... :? anyway ill try to put it again and see if it will work...
Multiple Checkbox Quiz sounds like an addon to the Ultimate Quiz MOD. It is quite likely that that is the cause of your problems.
GaVrA
hmmm ok, i think i made these changes:
http://www.phpbb.com/phpBB/viewtopic.ph ... 34#2838634
can u tell me whats the best way for me to do? :) is there some newest version or something to download? :)
GaVrA
hmmm it seems that i have forgoten to put something into includes/constants.php :D
muliple checkbox now works but i cant delete quiz with id 4... i had 1 quiz with multiple checkbox that didnt work, then i have deleted it, but it seems that it didnt go form the db, couse next quiz someone submited merged with that deleted one... :( and now after all that i cant delete that quiz with id 4 :(
help? :D
