I have installed this mod on my forum http://www.dinkydrinks.co.uk/forum.
As you can see the mod appears in the forum and i can see it in the admin panel... but i get this error when i click the link:-
error from clicking QUIZ in admin panel
Could not get category data
DEBUG MODE
SQL Error : S0002 [Microsoft][ODBC SQL Server Driver][SQL Server]Invalid object name 'phpbb_quiz_categories'.
SELECT * FROM phpbb_quiz_categories
Line : 338
File : admin_quiz.php
end of error
I get the following error when clicking the link to the QUIZZES from my forum home page:-
An Error Occurred
DEBUG MODE
Line : 984
File : quiz.php
Please help !!!
Install error... please help
I don't know much about MSSQL (which I assume is what you are using) but I would think that suggests you haven't run the database changes yet (quiz_install.php).
Hi Battye,
Cheers for the reply...
I have run the quiz_install.php - but for some reason the tables are not beeing inserted correctly using the install script u have provided.
Is there any chance you might now the changes needed to make it create them correctly.
Please advise as i think this is a great mod and wood dearly like to get it working for my members
kind regards
Jamie 2k
kind regards
Jamie 2k
If you look at the database using phpMyAdmin (if phpMyAdmin works with MSSQL... it might only work with MySQL in which case you will need to look using something similar) can you see the quiz_categories table. Or any of the quiz tables?
Did you get errors when running quiz_install.php?
No Errors... just no tables...battye wrote:Did you get errors when running quiz_install.php?
can i manually add them by running a ms sql insert ?
I don't have phpmyadmin on this server, as its not mine
I am however able to run sql inserts using MS Sql Enterprise manager... does same as phpmyadmin to all intents and purposes.
Please can you tell me if this is possible and if so which tables are needed for the install to function properly.
kind regards
Jamie
What do you mean?No Errors... just no tables...
When you ran the file what appeared on the screen? A lot of green text, red text???
If you wish to do it manually, you can. But it might take some time. Have a look inside quiz_install.php (open it in Notepad) for a list of the queries.
This was in the top of the page in black:-
Warning: odbc_exec(): SQL error: [Microsoft][ODBC SQL Server Driver][SQL Server]Line 2: Incorrect syntax near '`'., SQL state 37000 in SQLExecDirect in w:\vh\d\dinkydrinks.co.uk\forum\db\mssql-odbc.php on line 171
Warning: odbc_exec(): SQL error: [Microsoft][ODBC SQL Server Driver][SQL Server]Line 1: Incorrect syntax near '`'., SQL state 37000 in SQLExecDirect in w:\vh\d\dinkydrinks.co.uk\forum\db\mssql-odbc.php on line 171
This was then in a part of the page which looked like it had been created by the install script.
Ultimate Quiz MOD Installation
Ultimate Quiz MOD v1.2 Series
The script is now going to alter your forum database so the Ultimate Quiz MOD can function!
Any queries which are shown in green were executed successfully, those in red however, encountered a problem. It is absolutely vital that you have made all code changes already, and uploaded all quiz files to their respective locations.
CREATE TABLE phpbb_quiz ( `quiz_id` int(10) NOT NULL default '0', `quiz_name` varchar(200) NOT NULL default '', `quiz_author` int(10) NOT NULL default '0', `quiz_enabled` int(1) NOT NULL default '0', `quiz_category` int(5) NOT NULL default '0', `quiz_type` varchar(20) NOT NULL default '0', `quiz_plays` int(5) NOT NULL default '0');
CREATE TABLE phpbb_quiz_categories ( `category_id` int(5) NOT NULL default '0', `category_password` VARCHAR( 100 ) NOT NULL default '', `category_name` varchar(140) NOT NULL default '', `category_permissions` int(1) NOT NULL default '0', `category_description` varchar(255) NOT NULL default '');
CREATE TABLE phpbb_quiz_statistics ( `stats_id` int(5) NOT NULL default '', `quiz_id` int(10) NOT NULL default '', `user_id` int(10) NOT NULL default '', `stats_correct` INT(5) NOT NULL default '0', `stats_incorrect` INT(5) NOT NULL default '0', `stats_percentage` INT(3) NOT NULL default '0');
CREATE TABLE phpbb_quiz_multiple_choice_data ( `quiz_id` int(10) NOT NULL default '0', `question_id` int(10) NOT NULL default '0', `quiz_question` text NOT NULL, `quiz_alternates` text NOT NULL, `quiz_answer` text NOT NULL);
CREATE TABLE phpbb_quiz_true_false_data ( `quiz_id` int(10) NOT NULL default '0', `question_id` int(10) NOT NULL default '0', `quiz_question` text NOT NULL, `quiz_answer` text NOT NULL);
CREATE TABLE phpbb_quiz_input_data ( `quiz_id` int(10) NOT NULL default '0', `question_id` int(10) NOT NULL default '0', `quiz_question` text NOT NULL, `quiz_answer` text NOT NULL)
ALTER TABLE phpbb_sessions ADD `session_quiz_categories` VARCHAR( 255 ) NOT NULL;
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_show_answers', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Register_Play', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Post_Count_Play', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Post_Requirement', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Play_Once', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Author_Play', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Min_Max_Questions', '5,10')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Author_Mod', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Banned', '')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Moderators', '')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Stats_Display', '10')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Mod_Submit', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Currency', 'user_points')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Incorrect', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Correct', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Tax', '2')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_CashMOD_On', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_packs_category', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_packs_bot', 'Quartz')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_timeout', '10')
Installation is complete, however, some errors were encountered. It is suggested that you rectify these problems before attempting to use the Ultimate Quiz MOD!
i created the tables using a sql stripped from the quiz_install.php
this code created the tables with some strange looking names, which i changed... the structure and content in the tables looked ok
i edited the table names
but i now get the error from my insert about a stored procedure relating to 'user_id'
error
Server: Msg 2812, Level 16, State 62, Line 1
Could not find stored procedure 'user_id'.
please help... i am slowly loosing the desire to run a comp mod
error
I have to be honest with you, I've never used MSSQL, so my knowledge is very limited.
As for that error, I have no idea what it means. I can only assume that maybe one of the settings for that column is not correct (maybe a default value needs to be set for instance)
