I've updated to 1.3.3 but continue to get the "hacking attempt" error whenever quiz answers are submitted. Traced the alert to the following code - but not sure what is triggering it:
// Merge all into one extremely huge array; unset
// this later
$input = array_merge($HTTP_GET_VARS, $HTTP_POST_VARS, $HTTP_COOKIE_VARS, $HTTP_SERVER_VARS, $HTTP_SESSION_VARS, $HTTP_ENV_VARS, $HTTP_POST_FILES);
unset($input['input']);
unset($input['not_unset']);
while (list($var,) = @each($input))
if (in_array($var, $not_unset))
die('Hacking attempt detected !');
// unset($$var); // MOD Backslashes Added
unset($input);
Also, could you update your text file so we see the latest version available - the text file currently shows 1.2: http://www.cmxmods.net/quiz_latest.txt
Gephri wrote:I've updated to 1.3.3 but continue to get the "hacking attempt" error whenever quiz answers are submitted. Traced the alert to the following code - but not sure what is triggering it:
// this later
unset($input);
Have you made all the required changes? This was fixed in 1.3.1
And regarding the version, see Toy's post
It was to do with the radio boxes, and their name attribute being set to a number. From memory, to solve this, uqm_ was added in front of the variable. It was done in quiz.php IIRC
