Warning: file ---> help me please
wikette
Salut, j'ai installé la dernière version du MOD Ultimate Quizz et certain plantage aparaisse ...
J'ai pu résoudre quelques probleme sur des méssages anglais ou allemand mais la je bloque ...
Quelqu'un pourrait'il me filer un coup de main ???
____________________________________________________
Hello i'm french, I installed the last version of the MOD Ultimate Quizz and planting bug give…
Somebody maybe help me please.
(sorry for me bad english)
Warning: file(): URL file-access is disabled in the server configuration in /xxxxx/xxxx/xxxx/xxxxxx/xxxxxxx/forum/admin/admin_quiz.php on line 380
Warning: file(http://www.cmxmods.net/quiz_latest.txt): failed to open stream: no suitable wrapper could be found in /xxxxx/xxxx/xxxx/xxxxxx/xxxxxxx/forum/admin/admin_quiz.php on line 380
Hi :)
This is not a problem with the Ultimate Quiz MOD, your webhost is not allowing certain functions.
But do not worry, that error will not affect how the Ultimate Quiz MOD runs. It is a very minor problem, do not worry about it. :)
wikette
Ok, I have full with bug, and especially I cannot modify any more the option of configuration of quiz in the admin part.
I'm French.
Sorry for my bad English.
wikette
DEBUG MODE
SQL Error : 1146 Table 'larmonier_forum.QUIZ_STATISTICS_TABLE' doesn't exist
SELECT * FROM QUIZ_STATISTICS_TABLE WHERE quiz_id = 2 ORDER BY stats_percentage DESC LIMIT 10
Line : 107
File : quiz_stats.php
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'WHERE quiz_id = 2' at line 1
Line : 165
File : functions_quiz.php
Could not get actual quiz data for editing
DEBUG MODE
SELECT * FROM WHERE quiz_id = 2
Line : 180
File : quiz_cp.php
Unable to delete quiz data
DEBUG MODE
DELETE FROM QUIZ_STATISTICS_TABLE WHERE quiz_id = 2
Line : 266
File : quiz_cp.php
One entered of new table must the base sql????[/quote]
I'm French.
You haven't edited constants.php correctly.
wikette
Good I think of having reinstalled all well, however the last bug remains.
DEBUG MODE
SQL Error : 1146 Table 'larmonier_forum.phpbb_quiz_statistics' doesn't exist
DELETE FROM phpbb_quiz_statistics WHERE quiz_id = 1
Line : 266
File : quiz_cp.php
Thanks you very mutch.
I'm French.
wikette
Up!
I'm French.
If you look in phpMyAdmin, do you see a phpbb_quiz_statistics table?
wikette
Yes it is.
I'm French.
The error says it doesn't exist. Is your table prefix phpbb_ ?
To see what your prefix is, in phpMyAdmin, look in your forums database and see what the word before _forums or _posts is :)
wikette
Ok me table she called phpbb_quiz_statistic an not phpbb_quiz_statistics
I'm French.
wikette wrote:Ok me table she called phpbb_quiz_statistic an not phpbb_quiz_statistics
Add the s to the end :)
I think you can rename the table in the Operations menu.
wikette
Yessssssss so good
Thank you very mutch for your help.
I'm French.
You're welcome :)
Hope you continue to visit this forum, don't forget to go to OT Forum :D
