I changed so i got a new header on the portal,
it worked just fine, then 5 mins later this comes up:
Warning: main(http://www.volunteerforum.se/overallheader/RandomBanner/rotate_nr/9.php): failed to open stream: HTTP request failed! HTTP/1.1 404 OK in /home/volunteerforum/www/overallheader/RandomBanner/rotate_nr/banners.php on line 6
Warning: main(): Failed opening 'http://www.volunteerforum.se/overallheader/RandomBanner/rotate_nr/9.php' for inclusion (include_path='.:/usr/share/php:/usr/share/pear') in /home/volunteerforum/www/overallheader/RandomBanner/rotate_nr/banners.php on line 6
But this problem is still there..
Its the random banner script we talked about before.
And as i can see it, i cant even open the file that creates it =/
http://www.volunteerforum.se/overallhea ... anners.php
This code has always worked so =/
srand ((double) microtime( )*1000000);
$numbanners = 14;
$number = rand(0,$numbanners);
echo "<table align=center width=468 height=60><tr><td>";
include ("http://www.volunteerforum.se/overallheader/RandomBanner/rotate_nr/$number.php");
echo "</td></tr></table>";
to do whit me changing the header on the portal
So i temporarily removed this script from the header.
