Time limit
fighteur8
Hello,
i would like to speak about time limit in UQM :
the time limit is written in the main page of the quiz.
it would be better the time appears in the quiz_play_x template as a countdown.
for example, count the number of questions in the quiz, automatically start the countdown with the numbers of seconds remaining and do a redirection when it finishes
:wink:
That would require javascript or some other language I do not know. It isn't possible using PHP :)
fighteur8
I can help you ? 8)
If you have some javascript that you would like to contribute, feel free to post it here and I will see if I can implement it :)
e-mo
Hello..
I need help with the time issue. How can I set a longer time?! Lets say 15 or 20 seconds.
Currently..the time seems to be to short.
e-mo
Hi, this can be set within the Quiz Configuration in the ACP :)
e-mo
Hello battye,
sorry...but when I click on QUIZ in ACP I cannot see anything which says about the time :S
I checked Quiz Permission, Quiz Configuration and Quiz Cash Settings but do not see anything about time...
e-mo
When you upgraded to 1.3.0 (or 1.3.1 or 1.3.2) did you overwrite admin_quiz.php and the .tpl file for it?
e-mo
hm..
If I am not mistaken...I took the latest version for my board. how do I check what version I am currently running?
e-mo
