In my Overall_Header file i have this code:
<title>Volunteer Forum - {PAGE_TITLE}</title>
So all pages become: Volunteer Forum - "And the title here"
But when i add a titel at a website i created, there still is no
title as it should be.
Any idé why ?
Maybe fix this to the next version ?
page_title
Volunteer Forum Community
So you are putting <title>Volunteer Forum - {PAGE_TITLE}</title> in the actual HTML box?
I have that Code in my overall_header.tpl (Same whit META Tags)
And at the root of all files i have lets say
Links.php
In that file i create
// set page title
$page_title = 'Volunteer Links';
And for the page Aboutus.php in the root
i have
// set page title
$page_title = 'About Us';
(I also have a link.tpl in my morpheus folder, but that is not affected by this)
Links.php
// set page title
i have
// set page title
As long as $page_title is listed before the include_once(.......overall_header.php) it will work.
If $page_title is listed after that, then it will not work
I cant find any "include_once" in that file
overall_header.tpl
overall_header.tpl
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" dir="{S_CONTENT_DIRECTION}">
<head>
<meta http-equiv="Content-Type" content="text/html; charset={S_CONTENT_ENCODING}" />
<meta http-equiv="Content-Style-Type" content="text/css" />
<meta name="description" content="Volunteer Forum, Volontär Forum, Talk Discuss or Debate Volunteer 'ing" />
<meta name="keywords" content="Volunteer forum, Volontär forum, Community, Organisations, Portal, Website, Photo, Volunteer" />
<meta name="Author" content="http://www.phpbbstyles.com, Volunteer Forum" />
{META}
{NAV_LINKS}
<link rel="stylesheet" href="{T_TEMPLATE_PATH}/style_{TPL_COLOR}.css" type="text/css" />
<style type="text/css">
@import url("{T_TEMPLATE_PATH}/formIE.css");
</style>
<script language="javascript" type="text/javascript">
var PreloadFlag = false;
var expDays = 90;
var exp = new Date();
var tmp = '';
var tmp_counter = 0;
var tmp_open = 0;
exp.setTime(exp.getTime() + (expDays*24*60*60*1000));
function SetCookie(name, value)
var argv = SetCookie.arguments;
var argc = SetCookie.arguments.length;
var expires = (argc > 2) ? argv[2] : null;
var path = (argc > 3) ? argv[3] : null;
var domain = (argc > 4) ? argv[4] : null;
var secure = (argc > 5) ? argv[5] : false;
document.cookie = name + "=" + escape(value) +
((expires == null) ? "" : ("; expires=" + expires.toGMTString())) +
((path == null) ? "" : ("; path=" + path)) +
((domain == null) ? "" : ("; domain=" + domain)) +
((secure == true) ? "; secure" : "");
function getCookieVal(offset)
var endstr = document.cookie.indexOf(";",offset);
if (endstr == -1)
endstr = document.cookie.length;
return unescape(document.cookie.substring(offset, endstr));
function GetCookie(name)
var arg = name + "=";
var alen = arg.length;
var clen = document.cookie.length;
var i = 0;
while (i < clen)
var j = i + alen;
if (document.cookie.substring(i, j) == arg)
return getCookieVal(j);
i = document.cookie.indexOf(" ", i) + 1;
if (i == 0)
break;
return null;
function ShowHide(id1, id2, id3)
var res = expMenu(id1);
if (id2 != '') expMenu(id2);
if (id3 != '') SetCookie(id3, res, exp);
function expMenu(id)
var itm = null;
if (document.getElementById)
itm = document.getElementById(id);
else if (document.all)
itm = document.all[id];
else if (document.layers)
itm = document.layers[id];
if (!itm)
// do nothing
else if (itm.style)
if (itm.style.display == "none")
itm.style.display = "";
return 1;
itm.style.display = "none";
return 2;
itm.visibility = "show";
return 1;
</script>
</head>
<body bgcolor="#FFFFFF" text="#000000" link="#3B88C5" vlink="#3279B2" alink="#FF9C00">
<a name="top"></a>
<table border="0" cellspacing="0" cellpadding="0" width="100%" height="100%">
<tr>
<td width="10" class="border_left"><img src="{T_TEMPLATE_PATH}/images/spacer.gif" width="10" height="1" alt="" /></td>
<td width="100%" height="100%" class="content" align="center" valign="top">
<div id="header-box">
<div id="header-left"><a href="{U_INDEX}"><img src="{T_TEMPLATE_PATH}/images/{TPL_COLOR}/logo_left.gif" width="125" height="69" alt="{L_INDEX}" /></a></div>
<div id="header-right"><img src="{T_TEMPLATE_PATH}/images/{TPL_COLOR}/logo_right.gif" width="125" height="69" alt="" /></div>
<div id="header-center">
<b>{SITENAME}</b><br />
{SITE_DESCRIPTION}
</div>
</div>
<div id="navigation">
<!-- BEGIN switch_user_logged_out -->
<a href="{U_REGISTER}">{L_REGISTER}</a> |
<!-- END switch_user_logged_out -->
<a href="{U_INDEX}">Forum</a> |
<a href="{U_PORTAL}">Portal</a> |
<a href="websiteindex.php">Website</a> |
<a href="{U_ALBUM}">{L_ALBUM}</a> |
<a href="links.php">Links</a> |
<a href="{U_FAQ}">{L_FAQ}</a> |
<a href="{U_SEARCH}">{L_SEARCH}</a> |
<a href="{U_MEMBERLIST}">{L_MEMBERLIST}</a> |
<a href="{U_GROUP_CP}">{L_USERGROUPS}</a> |
<!-- BEGIN switch_user_logged_in -->
<a href="{U_PROFILE}">{L_PROFILE}</a> |
<a href="{U_PRIVATEMSGS}">{L_PRIVATEMSGS}{C_PM}</a> |
<!-- END switch_user_logged_in -->
<a href="{U_LOGIN_LOGOUT}">{CA_L_LOGIN_LOGOUT}</a>
</div>
<div id="content">
<!-- BEGIN switch_xs_enabled -->
<?php if($this->vars['CA_NEW_MSGS'] && $this->vars['PRIVATE_MESSAGE_INFO'] !== $this->vars['CA_L_NO_MSG'] && !defined('CA_POPUP_SHOWED')) { ?>
<div id="newmsgs"><a href="{U_PRIVATEMSGS}" class="newmsgs">{PRIVATE_MESSAGE_INFO}</a></div>
<?php define('CA_POPUP_SHOWED', true); } ?>
<!-- END switch_xs_enabled -->
<!-- BEGIN ca_new_privmsgs -->
{CA_XS_COMMENT_START}<div id="newmsgs"><a href="{U_PRIVATEMSGS}" class="newmsgs">{ca_new_privmsgs.TEXT}</a></div>{CA_XS_COMMENT_END}
<!-- END ca_new_privmsgs -->
That is not a php file. That is a html file (or most likely a .tpl file if this is for phpbb). You need to find the php file that that html file corresponds to.
Yeah, it's likely the file you would want to edit is Links.php
links.php
What has that file to do whit this ?
I cant even think of one reason why my links page
has something to do whit this problem.
As i said, i can not see the titel in a created website
by the mod.
Example:
Demo 1 - Titel: Volunteer Forum - - <--No titel
http://www.volunteerforum.org/forum/website.php?id=2
Another page: Volunteer Forum - Create a free blablabla <--Titel
http://www.volunteerforum.org/forum/portal.php?page=25
I think it has to do whit like:
website.php
Or something
Damn i'm annoying hehehe
by the mod.
Example:
website.php
Or something
It works when
It works when i add:
// set page title
$page_title = 'Website';
In the website.php
But then the problem is that all created websites gets the same topic.
// set page title
In the website.php
In website.php, find
Replace with
Does that do want you want?
'W_TITLE' => $title_website,
'W_TITLE' => 'Website - ' . $title_website,
I cant find that:
* website.php
* begin : Thursday, Jun 09, 2005
* copyright : (C) 2005 Battye @ CricketMX.com
* email : cricketmx@hotmail.com
* $Id: website.php, v1.000.0.00 2005/09/06 21:18:36 battye Exp $
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
$phpbb_root_path = './';
include($phpbb_root_path . 'config.'.$phpEx);
include($phpbb_root_path . '/includes/constants.'.$phpEx);
include($phpbb_root_path . '/includes/functions_website.'.$phpEx);
include($phpbb_root_path . 'includes/bbcode.'.$phpEx);
$userdata = session_pagestart($user_ip, PAGE_INDEX);
init_userprefs($userdata);
// End session management
/* // For testing purposes
$lang['No_website'] = 'No website has been configured at this address!';
$lang['No_website_chosen'] = 'No website has been entered';
$lang['MOD_provided_website'] = 'User Website MOD © <a href=http://www.cricketmx.com>battye</a> 2005';
$lang['Admin_website'] = 'Administer Website';
$lang['Admin_sitename'] = 'Select an appropriate name for your website:';
$lang['Admin_sitetext'] = 'Enter the HTML for your site here:<br /><span class="genmed">Or use site %stemplates%s!';
$lang['Admin_website_updated'] = 'Website updated successfully!<br />Click %shere%s to view your site!';
$lang['Admin_website_colour'] = 'Choose a background colour for your site:';
$lang['Admin_website_nav'] = 'Administer Website';
$lang['Admin_website_back'] = 'Click <a href="javascript: history.go(-1)">here</a> to go back and make changes, or Submit!';
$lang['Admin_website_view_template'] = 'View Templates';
$lang['Admin_wesbite_theme_name'] = 'Template Name';
$lang['Admin_wesbite_theme_desc'] = 'Template Description';
$lang['Admin_wesbite_theme_auth'] = 'Template Author';
$lang['Admin_wesbite_use_temp'] = 'Use Template';
$lang['Admin_wesbite_preview_theme'] = 'Preview Template';
$lang['Admin_css'] = 'Enter the CSS for your site here:';
$lang['Admin_user_banned'] = 'You have been banned from creating a website!<br />Please contact an administrator for further details!';
$lang['Admin_group_banned'] = 'This usergroup has been banned from creating a website!<br />Please contact an administrator for further details!';
$lang['Admin_user_low_post'] = 'You need to have at least %s posts to create a website!<br />Please contact an administrator for further details!';
$lang['Admin_mod_off'] = 'This feature has been disabled by an administrator.';
$lang['Admin_user_not_enabled'] = 'Users are not allowed to have websites!';
$lang['Admin_group_not_enabled'] = 'Usergroups are not allowed to have websites!'; */
// $lang['Admin_website_hits'] = 'This page has had %d hits!';
// Gotta remember to put this in constants.php
/* // User Website MOD
define('WEB_YES', '1');
define('WEB_NO', '0');
$uwm_lang = array();
$uwm_lang['TABLE_HEADING'] = 'Table Heading';
$uwm_lang['SITE_DESCRIPTION'] = 'Enter a description of your site here';
$uwm_lang['LINK_DESCRIPTION'] = 'Enter a description of your link here';
$uwm_lang['CONTENT'] = 'Enter content here';
$uwm_lang['FONT_FACE'] = 'Verdana';
$uwm_lang['FONT_SIZE'] = '2'; */
// Ok let's begin outputting the site.. not just yet though.. haha tricked you :-)
if(isset($HTTP_GET_VARS['id']) || intval($HTTP_GET_VARS['group_id']) && $HTTP_GET_VARS['mode'] != "owner")
uwm_enabled();
user_or_group_enabled($HTTP_GET_VARS['group_id']);
if(intval($HTTP_GET_VARS['id']) || intval($HTTP_GET_VARS['group_id']))
$id = (intval($HTTP_GET_VARS['id'])) ? $HTTP_GET_VARS['id'] : $HTTP_GET_VARS['group_id'];
if(intval($HTTP_GET_VARS['id']))
$hits = "UPDATE " . USERS_TABLE . " SET user_website_hits = user_website_hits + 1 WHERE user_id = " . $HTTP_GET_VARS['id'];
if(!$db->sql_query($hits))
message_die(GENERAL_ERROR, 'Could not update hit counter');
$sql = "SELECT * FROM " . USERS_TABLE . " WHERE user_id = '" . $id . "'";
if(intval($HTTP_GET_VARS['group_id']))
// Are they a member?
if(user_group_member($userdata['user_id'], $HTTP_GET_VARS['group_id']) == 2)
message_die(CRITICAL_ERROR, $lang['Admin_only_group_can_make_edit']);
$hits = "UPDATE " . GROUPS_TABLE . " SET user_website_hits = user_website_hits + 1 WHERE group_id = " . $HTTP_GET_VARS['group_id'];
$sql = "SELECT * FROM " . GROUPS_TABLE . " WHERE group_id = '" . $id . "'";
message_die(GENERAL_ERROR, 'Could not grab information');
while($user_website = $db->sql_fetchrow($result))
if (!$user_website['user_website_html'])
message_die(GENERAL_ERROR, $lang['No_website']);
$user_website['user_website_title'] = str_replace($chars, $tags, $user_website['user_website_title']);
$user_css = (isset($user_website['user_website_css'])) ? "<style type=\"text/css\"><br /><!--<br />" . $user_website['user_website_css'] . "<br />--><br /></style>" : ""; // Originally by Excursus
$bad = array("<script", "<form", "<iframe", "<?php", "?>", "<html>", "<body>", "</html>", "</body>");
$good = array("<script", "<form", "<iframe", "<?php", "?>", "<html>", "<body>", "</html>", "</body");
// Changed to htmlspecialchars() and back again, damn error, how was *I* to know it wanted parameter 1 to be a string :rolls eyes:
$title_website = (str_replace("''", "'", $user_website['user_website_title'])) ? str_replace("''", "'", $user_website['user_website_title']) : "";
$user_html = str_replace("''", "'", str_replace($bad, $good, $user_website['user_website_html']));
$user_html = bbencode_second_pass($user_html, '');
$colour = $user_website['user_website_colour'];
if($board_config['website_hits'] == WEB_YES)
$hits_out = sprintf($lang['Admin_website_hits'], $user_website['user_website_hits']);
$db->sql_close();
include($phpbb_root_path . "includes/page_header.$phpEx");
// Ok, do it...
echo '<html>';
echo $user_css; // Originally by Excursus
echo "<title>$title_website</title><table bgcolor=\"$colour\" width=\"100%\"><tr><td>";
echo $user_html;
echo '</body></html>';
echo '<br />';
echo '<font face="Arial">';
echo '<div align="center">User Website MOD © <a href=http://www.online-scrabble.com>battye</a> 2005<br />
Powered by <a href="http://www.phpbb.com/" target="_phpbb" class="copyright">phpBB</a> © 2001, 2005 phpBB Group';
echo '<br /><br />';
echo $board_config['website_footer'];
echo '<br />';
echo $hits_out;
echo '</div></td></tr></table></font>';
message_die(GENERAL_ERROR, $lang['No_website_chosen']);
if($HTTP_GET_VARS['mode'] == "owner" && $userdata['session_logged_in'])
uwm_enabled();
$sql = "SELECT * FROM " . GROUPS_TABLE . " WHERE group_id = " . intval($HTTP_GET_VARS['group_id']);
$sql = "SELECT * FROM " . USERS_TABLE . " WHERE user_id = " . $userdata['user_id'];
$gu_data = $db->sql_fetchrow($result);
if($HTTP_GET_VARS['view'] == "templates")
// From php.net: readdir
if(!(isset($HTTP_GET_VARS['filename'])))
if ($handle = opendir('./html_templates'))
$page_title = $lang['Admin_website_view_template'];
$template->set_filenames(array("admin_t" => "admin_view_site_template_body.tpl"));
/* This is the correct way to loop over the directory. */
while (false !== ($file = readdir($handle)))
if(get_site_template_html("description", $file) != '')
$file_link = "<a href='./website.$phpEx?mode=owner&view=templates&filename=$file'>$file</a>"; // Filename
$template->assign_block_vars('temp', array(
"U_LINK" => $file_link,
"U_DESC" => str_replace("Description: ", "", get_site_template_html("description", $file)),
"U_AUTHOR" => str_replace("Author: ", "", get_site_template_html("author", $file))));
$template->assign_vars(array(
"L_LINK_NAME" => $lang['Admin_wesbite_theme_name'],
"L_DESCRIPTION" => $lang['Admin_wesbite_theme_desc'],
"L_AUTHOR_NAME" => $lang['Admin_wesbite_theme_auth']));
$template->pparse("admin_t");
include($phpbb_root_path . "includes/page_tail.$phpEx");
if(isset($HTTP_GET_VARS['filename']))
$template->set_filenames(array("admin_vt" => "admin_consider_template_body.tpl"));
"U_NAME" => $HTTP_GET_VARS['filename'],
"U_FULL_DESC" => str_replace("Description: ", "", get_site_template_html("description", $HTTP_GET_VARS['filename'])),
"U_AUTH_NAME" => str_replace("Author: ", "", get_site_template_html("author", $HTTP_GET_VARS['filename'])),
"U_CSS" => nl2br(htmlspecialchars("<style type=\"text/css\">" . get_site_template_html('css', $HTTP_GET_VARS['filename']) . "\n</style>")),
"U_HTML" => nl2br(htmlspecialchars(get_site_template_html("html", $HTTP_GET_VARS['filename']))),
"U_FORM" => append_sid("website.$phpEx?mode=owner"),
"U_FORM_P" => append_sid("website.$phpEx?mode=preview"),
"U_HIDDEN" => str_replace("<", "<", get_site_template_html("html", $HTTP_GET_VARS['filename'])),
"L_PRE_TEMP" => $lang['Admin_wesbite_preview_theme'],
"L_DESC" => $lang['Admin_wesbite_theme_desc'],
"L_USE_TEMP" => $lang['Admin_wesbite_use_temp'],
"L_AUTHOR" => $lang['Admin_wesbite_theme_auth']));
$template->pparse("admin_vt");
if(isset($HTTP_POST_VARS['pre_temp']))
echo "<style type=\"text/css\"><br /><!--<br />" . get_site_template_html("css", $HTTP_POST_VARS['html']) . "<br />--><br /></style>";
echo get_site_template_html("html", $HTTP_POST_VARS['html']);
die();
if(isset($HTTP_POST_VARS['use_temp']))
$userdata_revised_text = get_site_template_html("html", $HTTP_POST_VARS['html']);
$userdata_revised_css = get_site_template_html("css", $HTTP_POST_VARS['html']);
$userdata_revised_text = stripslashes(str_replace("''", "'", $gu_data['user_website_html']));
$userdata_revised_css = stripslashes(str_replace("''", "'", $gu_data['user_website_css']));
check_web_ban("user", "");
if(isset($HTTP_GET_VARS['group_id']))
check_web_ban("group", $HTTP_GET_VARS['group_id']);
$page_title = $lang['Admin_website'];
$template->set_filenames(array("admin" => "admin_website_body.tpl"));
"L_ADMIN_WEBSITE" => $lang['Admin_website_nav'],
"L_SITENAME" => $lang['Admin_sitename'],
"L_SITETEXT" => sprintf($lang['Admin_sitetext'], "<a href='./website.$phpEx?mode=owner&view=templates'>", "</a>"),
"L_SITECOLOUR" => $lang['Admin_website_colour'],
"L_CSS" => $lang['Admin_css'],
"L_SUBMIT" => $lang['Submit'],
"L_PREVIEW" => $lang['Preview'],
"U_SITECOLOUR" => $gu_data['user_website_colour'],
"U_CSS" => $userdata_revised_css,
"U_SITENAME" => $gu_data['user_website_title'],
"U_SITETEXT" => $userdata_revised_text,
"GROUP" => (intval($HTTP_GET_VARS['group_id'])) ? $HTTP_GET_VARS['group_id'] : '',
"FORM" => append_sid("website.$phpEx?mode=sql")));
$template->pparse("admin");
if($HTTP_GET_VARS['mode'] == "sql" && $userdata['session_logged_in'])
uwm_enabled();
user_or_group_enabled($HTTP_POST_VARS['group']);
if(!$HTTP_POST_VARS)
message_die(CRITICAL_ERROR, 'No $HTTP_POST_VARS found!');
if(isset($HTTP_POST_VARS['preview']))
$site_text = bbencode_first_pass(str_replace("\'", "''", $HTTP_POST_VARS['Sitetext']), '');
$site_text = str_replace($chars, $tags, $site_text);
$site_title = str_replace("\'", "''", $HTTP_POST_VARS['Sitename']);
$user_css = (isset($HTTP_POST_VARS['Sitecss'])) ? "<style type=\"text/css\"><br /><!--<br />" . $HTTP_POST_VARS['Sitecss'] . "<br />--><br /></style>" : ""; // Originally by Excursus
$title_website = (str_replace("''", "'", $site_title)) ? str_replace("''", "'", $site_title) : "";
$user_html = stripslashes(str_replace("''", "'", str_replace($bad, $good, $site_text)));
$colour = str_replace("'", "''", $HTTP_POST_VARS['Sitecolour']);
$db->sql_close();
echo '<html><body bgcolor="' . $colour . '">';
echo $user_css;
echo "<title>$title_website</title>";
echo $user_html;
echo '<br />';
echo '<font face="Arial"><table width="100%"><tr><td align="center">';
echo $lang['Admin_website_back'];
echo '</td></tr></table></font>';
if(isset($HTTP_POST_VARS['submit']))
$site_css = str_replace("\'", "''", $HTTP_POST_VARS['Sitecss']);
if(intval($HTTP_POST_VARS['group']))
$sql = "UPDATE " . GROUPS_TABLE . " SET user_website_title = '$site_title', user_website_colour = '" . str_replace("'", "''", $HTTP_POST_VARS['Sitecolour']) . "', user_website_css = '$site_css', user_website_html = '$site_text' WHERE group_id = " . $HTTP_POST_VARS['group'];
$sql = "UPDATE " . USERS_TABLE . " SET user_website_title = '$site_title', user_website_colour = '" . str_replace("'", "''", $HTTP_POST_VARS['Sitecolour']) . "', user_website_css = '$site_css', user_website_html = '$site_text' WHERE user_id = " . $userdata['user_id'];
if(!$db->sql_query($sql))
message_die(GENERAL_ERROR, 'Could not update user website information');
message_die(GENERAL_MESSAGE, sprintf($lang['Admin_website_updated'], "<a href='./website.$phpEx?group_id=" . intval($HTTP_POST_VARS['group']) . "'>", "</a>"));
message_die(GENERAL_MESSAGE, sprintf($lang['Admin_website_updated'], "<a href='./website.$phpEx?id=" . $userdata['user_id'] . "'>", "</a>"));
Ok find:
Replace with
echo "<title>Website - $title_website</title><table bgcolor=\"$colour\" width=\"100%\"><tr><td>";
Does not seems to work.
http://www.volunteerforum.org/forum/website.php?id=3
Btw, should i maybe write something else then
<titel>blabla</titel>
in the:
website.php?mode=owner
page for it to work ?
Or use site templates!
Btw not even the page:
has an own titel
in the:
has an own titel
I want that the titel should come from:
"Select an appropriate name for your website:"
from the page: website.php?mode=owner
As it is here on this websitemod on your page.
I wonder why its not woring at my site =/
So my Demo 1 page could be
Volunteer Forum - Demo 1
if i use Demo 1 as name for that page
Does using that work?Leon wrote:Does not seems to work.
http://www.volunteerforum.se/website.php?id=3
in the:
has an own titel
ie. Typing <title>blabla</title> in the HTML box
