If you need help setting it up checkout MXStuff's set up guide here.
Enjoy!!
Download links:ChangeLog for WCS 1.8.5
version 1.8.5 (03-08-08) B&M
- less bandwidth used with the connected primaries
- Updated the help file with /logout
- added NullSoft installer ( win32 )
- The License agreement is now in the wcs installer ( win32 )
version 1.8.5 Beta3 (26-07-08)
- don't disconnect a chat client if we have reached the ping timeout ( 6 minuts)
Only trace this timeout in the console window of wcs and the log.
( FxServer haven't ping TimeOut)
version 1.8.5 Beta2 (12-07-08) B&M
- fixed bug with more 10 Blocked Words or Names
( wcs crashed ( Access Violation) if there was more 10 Blocked Words or
Names in the config.ini file).
ver 1.8.5 Beta1(08-07-08) B&M
compiled for XP with Dev-Cpp and mingw32 ( open source C++ IDE and compiler) --> no need of $$Microsoft Visual Studio .
- Modified some pieces of the source code to compile with gcc compiler.
- Fixed a bug (access violation) in the function ReplaceSensitive.
- Added a parameter (LongLines) to allow Lines until 800 characters (the limit was 400).
- Update Check Disabled.
- Added a graphic Configurator (Configurator.exe) to modify the file Config.ini
You can open it from the menu file of the WCS GUI.
You can open a help file from the menu help of the configurator GUI to understand the options.
This version has been released from the 1.8.4 KingMacro source code.
Because i didn't know the bugs of the 1.8.4 version, The bugs could be there again.
Please, Test this version and tell me what is wrong. I will try to fix the bugs.
ChangeLog for WCS configurator
ver 0.3 12/7/08 B&M
- fixed bug with empty customCommand
- fixed bug with passwords without Entry Message
- fixed bug with ReplaceWord :
- added a column ( W ) in the Replace List :
W is empty if the replace is a simple replace
W with value x if the replace is a ReplaceWord
- Updated the help file with ReplaceWord
ReplaceWord isn't in the Full Documentation web page of MXstuff.org
ver 0.2 12/7/08 B&M
- fixed bug with Password (Format and Entry message)
- fixed bug with CustomCommand and Replace
- fixed bug with License Agreement
Windows version: WCS v1.8.5.zip
Linux version: WCS v1.8.5.tar.gz
Thanks Bide&Musique
