Zenar Chat Server (ZCS)
Postby p2p-sharing-rules » Mon Jul 07, 2008 6:05 pm
Zenar has released his chat server.The newest version is beta 4.
You will need framework 2.0 installed to use his server.
If you don't have it installed on your PC you can download it here.
Here is the list of what I've done:
Beta #4
Rebuiled the "I'm talking" feature
Fixed a little bug on the primary part (It will also connect faster)
ZCS is now blocking illegal characters on usernames
Added a small feature to get more details when ZCS have bugs
Fixed a bug ZCS showed not the exact number of users in the channel
Fixed a little bug when sometimes the users had 65535 files...
The maximum length allowed for the rawname is now set to 50
Fixed the bug with the total downloaded datas to not get the negative values...
Fixed a little bug with the limit
This time, I've added a small feature to gather the informations when you get an unknown bug on ZCS. It will be sent to my server and that will help me to make this server better. You must know that I'm not receiving your personnal infos and here is an example of what I can get:
Bug=BUG-002=Attempted to divide by zero.
Beta #3
Fixed bug when doing a redirect... It will not show /redirect this time :-P
Fixed the problem while WPCC is sending many times the personnal message lol
Fixed a bug in the metis bug fix :-P
Added /ChannelName
Fixed the problem with the flood protection. (It blocked many chat clients / bots)
Added /BanIP
Added /KickIP
Fixed a little bug when resolving the hostname of certain hostnames
Added /Message
Added /PrivNotice
Beta #2
Fixed bug with unused ChannelName2
Fixed bug when the connection is lost, it makes ghost users...
Added client identification
Added flood protection
Added metis bug fix
Added /OnLine and /OffLine commands
The number of peers can be configured
Fixed a possible security issue with the usernames
Added /setcolor ;o)
Added ES feature to know when someone is typping a message (Working with WPCC for now)
Added WPNCaches
Protected users can modify themselves their settings (formats, access, etc...)
Fixed many minors and majors possible security problems
:cheers: Zenar. :)
Re: Zenar Chat Server (ZCS)
Postby p2p-sharing-rules » Sun Jul 13, 2008 9:30 pm
New update ZCS beta 5.2 released today.
What's New
Beta #5
You can now use newlines in action texts
The format message is now limited to 200 characters instead of 100 characters
The C access for caps is now working
Fixed the bug when you change the port and reload... It doesn't show the good hashlink...
I'm now blocking the 3.31 protocol
ZCS is showing to the client when the username already exists etc...
The limit of the number of users ZCS can handle has been set to 300
Added /Topic command
Added /SayAll command ;o)
Added /ZCS command
Added an option to be able to use the name of the format when you want to use /setformat
Added an option to be able to use the name of the access when you want to use /setaccess
Changed something in /stats[/code]
I've updated to Beta #5.2 because I fixed a major bug with the caps access lol
I'm off to try the new beta version.
:cheers: Zenar
Postby Zenar » Sun Jul 20, 2008 6:49 pm
Yep eveything is explained here!
Enjoy all! 8)
Zenar
Postby p2p-sharing-rules » Mon Jul 21, 2008 12:40 am
Thanks Zenar for creating a great server. :)
I would've had a uptime of over a week with it by now , but my explorer crashed & closed the server.
my current uptime is 4 days since I restarted it after my explorer crashed.
Postby battye » Mon Jul 21, 2008 5:25 am
Thanks for dropping by Zenar :)
Postby Zenar » Wed Jul 23, 2008 1:26 am
Here is my uptime for now:
21:27 Channel Uptime: 9d 5h 49m 15s
21:27 Current Users: 19
21:27 Total Joins: 306
21:27 Total Messages: 2520
21:27 Total Download Datas: 5.34GB
21:27 Total Upload Datas: 69.75MB
21:27 ZCS Version: ZCS Beta #5.2
I am hosting this version since I've released it (9 days ago :-P)
Zenar
Postby p2p-sharing-rules » Thu Jul 24, 2008 11:50 am
:lol: Nice your doing better then me with hosting a room with your server.
Postby Zenar » Mon Jul 28, 2008 12:29 pm
ZCS has been updated to V1.01!
Enjoy all 8)
Zenar
Postby p2p-sharing-rules » Tue Jul 29, 2008 2:01 am
ZCS V1.01 July 27, 2008
The 1st non beta release is available.
What's New & Changelog
Fixed a little bug when you only type /topic
Fixed a bug when an hidden user left the room
Fixed a possible security issue with /setaccess
The /Sayall access as been changed to W instead of w
Added /Say (w access required)
Added /Mute command
Added /Voice command
Added /Logout command
Added /SetTopic command and now /Topic command is only showing the topic :-P
Added exit message
Added rename message
Added client message
Added a little feature to fix a bug on shareguard >.> (Shareguard is now working)
Added /Help command
Added /Accesses (/Levels) command
Fixed bug with double users when the user start with + or @... Thanks Smokey for your help ;o)
Can unban with usernames
Added IPSend feature
Fixed a little bug in /setformat command
List of commands you can use:
/Login <Password> - To login in the room
/Logout - To get default access
/ZCS - To see the version of ZCS
/ChannelName - To see the channelname
/ForceLogin <UserName> <Password> - To login someone else
/Message <UserName> <Message> - To send a private message to someone
/Notice <Message> - To send a notice to the room
/Say <UserName <Message> - To speak with the name of someone else
/SayAll <Message> - All users will say the message
/PrivNotice <UserName> <Message> - To send a private notice to someone
/Hide - /Hide <UserName> - To hide yourself or someone else
/HideCmd <Command> - To hide a command
/Mute <UserName> - /Unvoice <UserName> - To mute someone
/Voice <UserName> - /Unmute <UserName> - To voice someone
/Bot - To enable or disable bot mode
/Colour - To see the available colors
/SetColour <Color number> - To set yourself a text color
/SetFormat <UserName> <Format> - To set a format to someone
/Access - /Level - To see your current access
/SetAccess <UserName> <Access> - To set an access to someone
/AddAccess <UserName> <Access> - To add an access to someone (Only one character is allowed)
/RemAccess <UserName> <Access> - To remove an access to someone (Only one character is allowed)
/Motd - To see the Motd
/Topic - To see the topic
/SetTopic <Topic> - To set a topic
/Limit <Number> - To set a limit of users on ZCS
/Ban <UserName> - To ban someone
/BanIP <IP> - To ban an IP
/ClearBans - To clear the list of banned users
/UnBan <UserName or IP> - To unban someone or an IP
/ListBans - To see all banned users
/KickBan <UserName> - To kick and ban someone
/Kick <UserName> - To Kick someone
/KickIP <IP> - To kick all users using the IP
/Stats - To see channel stats
/Stats <UserName> - To see user stats
/Peers - To see all peers connected by ZCS
/Who - To see the list of users with infos
/Accesses - /Levels - To see all access letters
/Help - To see this list
/Exile <UserName> <ChannelName> - To send an user to another room
/Redirect <ChannelName> - To redirect all users to another channel
/Reload - To reload the configuration
/Online - To show the room from the WPN
/Offline - To hide the room from the WPN
/Opmsg <Message> (/ ) - operator message requires O access level
/Admsg <Message> (//) - admin message requires A access level
/Me or /Action <Message> - action/emote message
#\n# or #NEWLINE# - Newline
Thanks for the update Zenar. :D
Postby p2p-sharing-rules » Wed Jul 30, 2008 8:02 am
New update for ZCS V1.02 on: July 29, 2008.
Changelog for V1.02:
Fixed robomx bug
ZCS is showing "This channel is hosted on ZCS V1.02 [Linux]" instead of using two lines
Improved the flood security
:cheers: ty Zenar
Postby p2p-sharing-rules » Sat Mar 14, 2009 9:17 pm
ZCS v1.03 Test #1
A new test version of ZCS is available for testing. I recommend if you're using ZCS to host your chat room that you don't use it for your main chat room and that you open a test chat room if you want try it out.
V1.03 Test #1
Fixed a bug when you put nothing on ClientMSG, RenameMSG or ExitMSG (It will show nothing instead of the default message)
Fixed a mistake with the rename part... I forgot to add a feature to improve the security
Added Include - You can now use include= to split your configs into many files. That makes your life a little easier ;o)
Added SameIPMSG - ZCS tells you if someone else enter with a same IP
Changed ReplaceWord for ReplaceALL
Added ReplaceWord
Changed access letters for (RenameMSG = e) (ExitMSG = X) (SameIPMSG = i) make sure you update your config files
Show the new topic when it's changed and config.ini is reloaded
Added %STAYTIME% variable
Modified the variables of the flood protection
I forgot to add a feature to kick someone when the user change his name and that name is blocked... fixed now
Added the message part when someone login (Just like on WCS)
ZCS is now listing in WCB and other KM's programs
Postby Zenar » Sat Mar 14, 2009 9:31 pm
You are very fast p2p-sharing-rules lol
He said everything :-)
Zenar
Postby p2p-sharing-rules » Sat Mar 14, 2009 9:38 pm
Thanks Zenar. :)
Postby p2p-sharing-rules » Wed Mar 18, 2009 3:23 pm
Zenar released a new test version.
V1.03 Test #2
Fixed /logout command
Fixed a big issue with the supposly fixed rename part (Secondary users were kicked when they changed node)
Thank you Zenar. :mrgreen:
Note: I put online the file again because I can't test WCB if nobody is using ZCS :-P
Postby p2p-sharing-rules » Mon May 25, 2009 7:05 am
Zenar created a forum. Here's the url http://www.zenmx.com/ .
Next
Return to P2P File Sharing
