Page 5 of 5
Re: New BitComet Version Released
Posted: Fri Jan 21, 2011 8:46 am
by p2p-sharing-rules
BitComet 1.25
Release date: Dec 8, 2010
Changelog
GUI Improved: new global option: customize actions of mouse double-click on task list
GUI Improved: show log of trackers from tracker list
GUI Improved: display progress bar of disk space in task properties dialog
GUI Improved: add Torrent History button to toolbar of task list
GUI Improved: add task list button to toolbars of Torrent History ad Torrent Share
GUI Improved: remember sort state of task list after program restart
GUI Improved: new icon for Torrent History
GUI Improved: VIP Acceleration can be canceled if a task can not complete for a long time
GUI Bugfix: UNC path can not be set as default download folder in option dialog
Core Bugfix: improve kernel stability
Core Bugfix: improve stability of BHO
download links:
BitComet 1.25 setup.exe
BitComet 1.25.zip
Posted: Fri Jan 28, 2011 12:27 am
BitComet 1.26
Release Date: Jan. 27, 2011
Changelog
GUI Improved: improve text information displayed in VIP acceleration dialog
GUI Improved: improve progress bar of disk space in task properties dialog
GUI Improved: new setting in advanced option page to enable/disable auto hash check after downloaded file changed
GUI Improved: new setting in advanced option page to enable/disable disk boost service (only Vista and later)
GUI Improved: display the status of disk boost service in statistical tab (only Vista and later)
GUI Improved: tasks in queue will be displayed in Active task list
GUI Improved: improve re-connection timers displayed in tracker list
GUI Improved: do not display torrent downloading prompt dialog when open a magnet link
GUI Improved: improve GUI font when choosing Traditional Chinese in non-Traditional Chinese Windows
GUI Improved: simplify torrent status icon in torrent history and torrent share list
GUI Improved: do not fix the width of date column in torrent history and torrent share list
GUI Improved: improve display refreshing code of torrent history and torrent share list, reduce CPU usage
GUI Improved: display the default command in context menu of torrent history and torrent share list as bold
GUI Improved: new command in context menu of Torrent Collect list: Add to Torrent Share
GUI Improved: add openbittorrent and publicbt as default trackers when creating torrents
GUI Improved: green light appears after incoming connection established from a remote peer
GUI Improved: add large icon of 256*256 for Vista/Win7
GUI Improved: add new column to Torrent History list: private torrent
GUI Improved: do not lock the width of preview column in task list
GUI Improved: display total download time in task summary tab
GUI Improved: display the number of days in case of downloading left time is more than 24 hours
GUI Improved: check downloaded files at program startup, and display warning icon on task if file missing. It can be disabled in advanced option page.
GUI Changed: Long-Time Seeding renamed to Long-Term Seeding
GUI Bugfix: the downloaded size in task statistical dialog when selecting multiple tasks is invalid
GUI Bugfix: when mouse cursor hovering on system tray icon in XP, the task running info balloon can not be shown
GUI Bugfix: the delete button in toolbar grayed out when pressing Ctrl to select multiple items in Torrent History and Torrent Share
GUI Bugfix: in the global option dialog, the max value of cache size for each connection of HTTP download should be 2MB
GUI Bugfix: after torrent downloaded for Magnet URI, the hidden options in advanced page of task properties dialog is not shown right away
GUI Bugfix: the error message of failure to listen on UDP port is not accurate
Core Improve: using disk boost service to create large files when start downloading, to speed up disk operation, avoid UI no response (only Vista and later)
Core Improve: improve kernel to reduce CPU usage for UI refreshing when downloading BitTorrent task
Core Improve: connect to one only tracker at a time when downloading private torrent, and clear all peers when switching tracker
Core Improve: improve crash report program
Core Improve: improve transport interval of peer exchange
Core Improve: use worker thread to process socket message, thereby reduce message handling in UI thread
Core Bugfix: do not connect to tracker when remove a tracker from tracker list (thanks to kluelos)
Core Bugfix: when listening port disabled in option dialog, program will dead-loop when exit
Download links
BitComet 1.26 setup.exe
BitComet 1.26.zip
Posted: Wed Apr 27, 2011 2:06 am
BitComet 1.27
Release Date: April 22, 2011
Changelog
GUI Improved: display Batch Download window when drag&drop multiple torrent files to main window or floating window
GUI Improved: remove the drop-down menu from the delete button in toolbar of Torrent History or Torrent Share list
GUI Improved: add "Show Detailed Info" option in View menu
GUI Improved: new setting in option dialog: add to Torrent Share when opening torrent
GUI Improved: display translation text of "Day" and "Hour" in task left time
GUI Improved: display recovered and dropped data size by hash-checking in task log list
GUI Improved: display used memory size in Statistics pane
GUI Improved: new setting in Advanced Option page: max number of UDP packets sent per second
GUI Improved: display upload/download speed in the left of main window's title bar
GUI Improved: display more accurate error info when opening Magnet URI of unsupported types
GUI Improved: display preview window of task downloading progress when mouse hovers on floating window or system tray icon
GUI Improved: display Batch Download window when open multiple torrent files from File menu
GUI Improved: display confirm window if tasks need hash-check when started
GUI Improved: add new global option: display hash-check confirm window
GUI Improved: enhance video file capture ability of Firefox extension
GUI Improved: max cache size in global options page up to 16 GB under 64-bit system
GUI Improved: display download/upload size of this session in Statistics pane
GUI Improved: drop-down menu of remove button in toolbar is removed. click remove button with shift key can remove download task and files together
GUI Improved: decrease the context menu level of floating window and system tray icon
GUI Improved: available space can be displayed correctly even if the save folder is a symbol link to other volume
GUI Improved: improve the crash report program
GUI Improved: new task list of VIP Downloads
GUI Improved: "delete task and files" removed from task context menu. click "delete task" menu command with shift key to delete download task and files together.
GUI Improved: support context menu of IE 9 to download using BitComet
GUI Improved: modify the size of BT task properties dialog, compatible with 1024x600 resolution
GUI Improved: display navigation pane of Windows Explorer when open task download folder under Windows XP
GUI Improved: the text of task status in summary pane can't be displayed completely when it's too long
GUI Improved: new button in toolbar: add Magnet URI
GUI Improved: BitComet video download extension for Firefox supports Firefox 4
GUI Improved: BitComet plugin for Firefox supports Firefox 4
GUI Improved: un-installation program will notify running BitComet to exit
GUI Changed: update check for popular software removed totally
GUI Changed: remove the "Don't show again" option in task remove confirm window
GUI Bugfix: "Open Forum" button in toolbar become invalid when file list is showing
GUI Bugfix: after remote connection established, the network status light turns green, but the tooltip of the light and the listening port status in Statistics pane not refreshed
GUI Bugfix: in v1.26, certain settings in Proxy page can't be saved
GUI Bugfix: in v1.26, unable to create new tag from Task Tag option page
GUI Bugfix: in v1.26, the seed number not displayed in task summary pane
GUI Bugfix: the option "add to Torrent Share when opening torrent" doesn't work
GUI Bugfix: when mouse hovers on the system tray icon, the preview window of task downloading progress displayed in incorrect position
GUI Bugfix: the detail info windows of download/upload size in task summary pane couldn't be able to shown up after program running for a long time
GUI Bugfix: the task state icon displayed as warning if only download part of files of a BitTorrent and choose "Download Later"
GUI Bugfix: after increase text size of Windows (DPI setting), the layouts of certain windows went wrong
GUI Bugfix: the function of shutdown computer after all task download finished ignores tasks in queue
Core Improve: native support for 64-bit system
Core Improve: read file in working thread after disk cache of BitComet used up, to avoid UI responding slowly while high-speed seeding
Core Improve: slow down download speed when disk writing speed can not catch up, to avoid UI responding slowly while high-speed downloading
Core Improve: improve uploading queue handing, to boost uploading speed in LAN
Core Improve: if the the download drive not accessible when task starts, hash-check will be skipped to avoid download progress be reset
Core Bugfix: stop and restart BT task containing 0 size files will lead to unnecessary hash-checking
Core Bugfix: drop incoming peers whose listening port is unknown when their connection disconnected
Core Bugfix: files not closed after task stopped as disk space full, making those files locked for moving or removing
Core Bugfix: if only select part of files in a BitTorrent download, the task progress may fall back after hash-checking
Core Bugfix: when the setting of allocate space before downloading enabled, only the space of the first 50 files is allocated
Core Bugfix: if the save folder is a junction of directory, the download will fail
Core Bugfix: download rate limit for single BT task not applied to downloading from Long-Term Seeds
Download links
BitComet 1.27.exe
BitComet 1.27.zip
