New BitComet Version Released
Postby p2p-sharing-rules » Sun Nov 19, 2006 3:35 pm
BitComet v0.77 Nov. 18 , 2006.
What's new
GUI Improved: add recycle bin to place tasks deleted temporarily
GUI Improved: add toolbar button, task list context menu item and Delete hot-key to delete task to recycle bin
GUI Improved: add the function to to capture http/ftp file download in IE
GUI Improved: add a setting to specify the file types to be captured when IE downloads file in in preferences dialog
GUI Improved: add "Download Videos using BitComet" command in IE context menu as a option
GUI Improved: adjust postion of splitters automatically when resizeing main window to keep optimal layout
GUI Improved: display translated text in status-bar in the language of user chosen when mouse hover in the toolabr
GUI Improved: dislpay the number of imported urls in the selection dialog of download all links in webpage
GUI Improved: new toolkit: FlvPlayer
GUI Bugfix: fix the bug that the task list is cleared and not displayed after switch UI language
Core Improved: add the function of searching mirror site automatically for HTTP download task
Core Improved: add the function of download video files in webpage
Core Bugfix: fix the bug that the program may crash when only download partial files in a BT task
Download links:
BitComet v0.77.exe
BitComet v0.77.zip
Postby p2p-sharing-rules » Thu Dec 07, 2006 4:17 am
BitComet v0.79 Nov. 30 , 2006
Download links:
BitComet_0.79_setup.exe
BitComet_0.79.zip
Release Notes
Postby p2p-sharing-rules » Sat Dec 16, 2006 9:34 pm
BitComet v0.80 Dec. 15 , 2006
What's New
GUI Improved: new designed HTTP properties dialog layout
GUI Improved: start preview video file while http downloaing from toolbar button or task context menu
GUI Improved: support display URL with non-English UTF-8 characters correctly in English version Windows
GUI Improved: display "Minimize to tray" in task-bar context menu of BitComet if enabled
GUI Improved: new setting of "Optimize download strategy for preview" in Task setting page of preferences dialog
GUI Improved: add move file to desktop and to My Document function in task context menu
GUI Improved: after downloaded torrent file using BitComet, the torrent task properties dialog is displayed immediately
GUI Improved: toolkit FlvPlayer support running under Windows 2003 now
GUI Improved: toolkit FlvPlayer is able to seek while playing for most flv files now
GUI Bugfix: fix the bug that the description info in HTTP properties dialog not been saved after user modified
GUI Bugfix: fix the bug that the number of selected urls in url selection dialog not refreshed after applied filter
GUI Bugfix: fix the bug that BitComet not able to launch FlvPlayer to play downloaded flv file in whose path has space character
Core Improved: HTTP download task support video file preview, etc. play video file during downloading
Core Improved: support to download URL with non-English UTF-8 characters in English version Windows
Core Improved: able to change HTTP connection number during task running
Core Bugfix: fix the bug that the program will lose response when decrease max downloading task number while any task running
Download links:
BitComet v0.80 Setup
BitComet v0.80.zip
Postby p2p-sharing-rules » Mon Jan 01, 2007 10:18 pm
BitComet v0.81 Dec. 27, 2006
What's New:
GUI Improved: new floating window to display running status, supporting drag&drop of links in webpage and files to start download
GUI Improved: add new function of auto query file size and server resume-supported ability when add new HTTP task, which can be configured in preferences dialog
GUI Improved: the task number of a task queue is displayed in the favorites list
GUI Improved: new icons for HTTP task states in task list
GUI Improved: link count is displayed in add HTTP task group dialog
GUI Bugfix: fix the bug that URL can not be opened from BitComet if FireFox is set to be default browser
Core Improved: new function of auto recycle memory, which can be configured in preferences dialog
Core Improved: compatible to Windows Vista, able to download HTTP links from IE7
Download links:
BitComet 0.81_setup.exe
BitComet 0.81.zip
Postby p2p-sharing-rules » Sun Jan 21, 2007 9:42 pm
BitComet v0.82 Jan. 19 2007
What's New:
GUI Improved: add sound prompt when task download finish, which can be configured in preferences dialog
GUI Improved: improve the context menu of floating window and system tray icon
GUI Improved: processing progress dialog will be displayed when add http task group
GUI Bugfix: fix the bug that the task start order is not correct if reduce task queue length while the queue is not empty
GUI Bugfix: fix the bug of version 0.81 that program can not run under win98/me
Core Improved: the NAT port mapping and Windows Firewall operation is moved to a separated toolkit program, therefor the CPU usage of main program decrease
Core Bugfix: fix the bug that the preview window will lose response if click stop button while preview video file of BT task
Download:
BitComet v0.82.exe
BitComet v0.82.zip
Postby p2p-sharing-rules » Thu Feb 08, 2007 12:38 am
BitComet v0.83 Feb. 4 2007
GUI Improved: add option in HTTP task properties dialog to enable P2P http download
GUI Improved: add hot key Ctrl+R in add HTTP task group dialog, to replace selected text in url to wildcard "(*)"
GUI Improved: refer page url is filled to new http task when drag URL from IE to floating window
GUI Improved: new network rate graph of the floating window in large size
GUI Improved: improve the IE context menu for BitComet, add sub menu to download particular objects in the webpage
GUI Improved: add comment and preview/play column in task list
GUI Improved: WAN IP and network connection status is displayed in status bar of the main window, showing if the listen port is reachable to public domain peers
GUI Improved: enhance the RSS list display function
GUI Improved: add options in perferences dialog to enable network connection status auto check
GUI Improved: add options in perferences dialog to enable task statistical info submitting
GUI Bugfix: fix the bug that "save torrent as" in task context menu will save other task's torrent file if catogory is selected in fav list
GUI Bugfix: fix the bug of the sort operation in task list
GUI Bugfix: fix the bug that the URL link name is not displayed in the selection dialog of downloading all links
GUI Bugfix: fix the display bug of floating window in Windows Vista
GUI Bugfix: fix the bug that the task list is not refreshed after cancel the operation of add HTTP task group
GUI Bugfix: fix the display bug of the HTTP task info window when switching selected task
Core Improved: add P2P download function to HTTP task, able to search more peers to speed up downloading
Core Improved: reconstruction NAT Traversal via UDP using encription connections
Core Improved: improve the robustness of video file preview. the crash of video codec will not terminate BitComet main program
Core Bugfix: fix the bug that HTTP download resume will fail if the web server is rebooted
download:
BitComet v0.83.exe
BitComet v0.83.zip
Postby p2p-sharing-rules » Sun Feb 11, 2007 10:16 pm
BitComet v0.84 Feb. 08 , 2007
Release Notes
GUI Improved: new task piece graph for both BT and HTTP, displaying detail file piece downloading state
GUI Improved: enhanced video codec version detection for preview. the extra video codec check wizard is removed.
GUI Improved: add clipboard monitor, which can be enabled in floating window context menu
GUI Bugfix: fix the bug that fail to open torrent file during preview
GUI Bugfix: fix the bug that the UPNP opeartion results are not displayed in statistics view
GUI Bugfix: fix the bug that the floating window is not hide when hit boss key
Core Bugfix: fix the bug that the uplading rate is too low in some situation
Core Bugfix: fix the bug in the decode of GZIP data returned from HTTP server
Download links:
BitComet v0.84 .exe
BitComet v0.84.zip
Postby p2p-sharing-rules » Mon Mar 19, 2007 6:39 pm
New BitComet v0.85 March 19 2007
Release Notes:
GUI Improved: new option in torrent maker dialog to enable large file(>1MB) align to piece boundary
GUI Improved: new option in torrent maker dialog to allow user search for HTTP/FTP resources when BT downloading
GUI Improved: new option in BT task properties dialog to enable search for HTTP/FTP resources for BT task files
GUI Improved: new history task filter in fav list, in which tasks displayed in the order of download finish date
GUI Improved: improve task delete dialog, able to remove downloaded files while keep task record in recycle bin
GUI Improved: new option in preferences dialog to enable BT task access P2PCache server (need ISP support)
GUI Improved: task created date and finish date are displayed in task summary
GUI Improved: improve task piece graph, support page down using mouse wheel
GUI Improved: new recomment side-bar which can be toggled in view menu
GUI Improved: BitComet main window minimize to windows taskbar, and system tray icon always displays
GUI Improved: if the task name/publisher name in task list is too long to display, it will be displayed in tooltip
GUI Improved: new search toolbar in the top of BitComet passport view
GUI Improved: improve the clipboard monitor, only capture url links of specific files type
GUI Improved: add support for Maxthon browser
GUI Improved: unhide the option of browse url in BitComet
GUI Improved: downloaded file will be selected when open task save folder
GUI Bugfix: fix the bug that some HTTP download fail due to missing cookie info
GUI Bugfix: fix the bug that hash check of multi BT tasks not running in queue
GUI Bugfix: fix the bug that move to other location command in task context menu does not work
GUI Bugfix: fix the bug that some particular language can not be input to IE edit control when BHO loaded
Core Improved: add P2SP download function to BT task, able to search for HTTP/FTP resources to accelerate download
Core Improved: add large file(>1MB) align to piece boundary function to torrent maker and BT download module
Core Bugfix: fix the bug that may lead to crash when download HTTP task using P2P connection
Core Bugfix: fix the bug that may lead to crash when an error UDP packet received
Core Bugfix: fix the bug that downloaded file may save fail if unsupported characte in current code-page occurred in torrent file
Core Bugfix: fix the bug about GZIP decode in HTTP 1.0
Core Bugfix: fix the bug that the task created from BCTP link is not properly saved if torrent had not downloaded.
Core Bugfix: fix the bug that unable to connect to some FTP server
Download links:
BitComet v0.85.exe
BitComet v0.85.zip
Postby p2p-sharing-rules » Wed Apr 04, 2007 9:33 pm
BitComet 0.86 April 03, 2007.
What's new:
GUI Improved: new torrent share function: click my sheard or peer shared in fav list to manage shared torrents
GUI Improved: add option to calculate ED2K link for each file in torrent make dialog
GUI Improved: add preset button to choose preset save folder in BT task properties dialog
GUI Improved: add option to download from the mirror when the source url can't be connected in HTTP task properties dialog
GUI Improved: remove movie info related staffs from torrent make dialog and BT task properties dialog
GUI Improved: add mark highlight button and filter popup menu to download all links dialog
GUI Improved: add server mode option to preferences dialog, which support more connections but can't set precise rate
GUI Improved: improve search box in toolbar of main window
GUI Improved: if choose to open URL inside BitComet, new web window will open, without effect to main window
GUI Improved: after a torrent file downloaded by http task, the BT download will start automatically
GUI Improved: HTTP/FTP resources number for BT task is displayed in file list
GUI Improved: add hotkey PageUp/PageDown, Ctrl+Left/Right and Alt+Left/Right for preview window to seek 10 sec, 30 sec and 120 sec
GUI Improved: bufferred time length is display in status bar when preview
GUI Improved: when close BT/HTTP task properties dialog, save folder and filename is verified to be valid
GUI Bugfix: ban IP menu in peer list of BT task do not work sometimes
GUI Bugfix: avoid system entering suspend/sleeping mode do not work in Windows Vista
GUI Bugfix: left time in task list is not correct if task size is too largr or download rate is too low
Core Improved: new torrent share function, to download torrent files from peers
Core Improved: support HTTPS download
Core Improved: support download FTP resource for BT task
Core Improved: improve SHA1 algorithm, decrease CPU usage
Core Improved: improve NAT Traversal via UDP component, decrease CPU usage
Core Bugfix: upnp.exe launch fail in Windows 2000
v0.85 2007.03.19
Download links:
BitComet 0.86.exe
BitComet 0.86.zip
Postby p2p-sharing-rules » Wed May 09, 2007 3:36 pm
New BitComet v0.87 May 08, 2007
Release Notes:
GUI Improved: add an option in BT task properties dialog to add this torrent file to my shared torrent list
GUI Improved: add "view task" command to the context menu of my shared torren list
GUI Improved: add a filter in the toolbar of peer shared torrent list
GUI Improved: display peer shared torrent file number in peer shared node of fav list
GUI Improved: add an option to enable BT task search for HTTP/FTP download source in perferences dialog
GUI Improved: add commands to import/export task list and global settings under file menu
GUI Improved: add "rename task" function in context menu of task list
GUI Improved: detail error information will be displayed in tooltip when mouse cursor hover on the red-cross icon of a task which encounter error like disk full
GUI Improved: task rating information will be displayed in tooltip when mouse cursor hover on comment region of the task list
GUI Improved: add hotkey Ctrl+Home/End to move selected tasks to the top/bottom of task list
GUI Improved: support scroll information in all panes on which the mouse cursor is hovering by rolling mouse wheel
GUI Improved: add an options in perferences dialog to enable submit video file snapshot after task download finish
GUI Improved: add an options in perferences dialog to enable protection against ARP cheating attack from LAN
GUI Improved: new designed BitComet resource browser to accelerate open web page from BitComet
GUI Improved: improve displayed information layout in task summary pane
GUI Improved: add "minimize to system tray" to system menu of BitComet button in windows taskbar
GUI Improved: delete file check box in task delete dialog is displayed in red color
GUI Bugfix: View/download list/Columns menu does not work after switch UI language
GUI Bugfix: all tasks will be displayed as in queue if enabled auto-start task when download rate below specified value
GUI Bugfix: all tasks displayed in task list will be removed if launch clear recycle bin in recycle bin context menu even they are not in recycle bin
Core Bugfix: fix a bug sometimes lead to memory leakage
Core Bugfix: handle some BT task with zero-size file incorrectly
Download Links:
BitComet v0.87 setup.exe
BitComet v0.87.zip
Postby p2p-sharing-rules » Fri May 25, 2007 8:57 pm
New BitComet v0.88 , May 24, 2007
GUI Improved: add an option to verify login password at program startup in perferences dialog
GUI Improved: add default task related info pane option in perferences dialog
GUI Improved: add an option to set Bitcomet as default IE download tool in perferences dialog
GUI Improved: add an option to enable torrent share in perferences dialog
GUI Improved: open BCTP link dialog replaced by open BC link dialog, which can create HTTP/FTP/BT task from BC link
GUI Improved: add "copy BC link to clipboard" command to task list context menu, with hotkey Ctrl+C
GUI Improved: add snapshot number column in task list
GUI Improved: add tooltip to display detail task status info when mouse hover on task icon in task list
GUI Improved: add tooltip to display upload rate, left time, health when mouse hover on download rate, progress, seed number
GUI Improved: upload rate, left time, health will not display in task list by default (can be shown in View menu)
GUI Improved: when task stopped, task can be renamed even if task is not completed
GUI Improved: double click to download torrent file in peer shared torrent list
GUI Improved: add popular column in peer shared torrent list
GUI Improved: new icon and tooltip to designate whether the torrent has been downloaded or shared by me in peer shared torrent list
GUI Improved: add auto-refresh checkbox in toolbar of peer shared torrent list
GUI Improved: add share-all checkbox in toolbar of my shared torrent list
GUI Improved: improve statistic pane display effect
GUI Improved: add save file already exist check when open torrent file to create new BT task
GUI Improved: able to save files to UNC path of shared folder in network during HTTP/BT downloading
GUI Improved: add warning prompt if save file large than 4GB to non-NTFS volume when create HTTP/BT task
GUI Improved: add balloon prompt on disk full error during HTTP/BT downloading
GUI Improved: add prompt dialog to close program and send error report when program is not responding
GUI Improved: add context menu to WAN IP detect light in status bar of main window
GUI Improved: remove some infrequent options in perferences dialog
GUI Improved: floating window remember its postion and size automatically
GUI Bugfix: unfinished tasks will not auto-start at program startup if BitComet is not closed normally before shut down computer
GUI Bugfix: average download rate in task summary pane is cleared after BT task stopped
GUI Bugfix: comment number and snapshot number in shared torrent list is not refreshed in time
GUI Bugfix: operation to torrent will be misplaced after sort shared torrent list
GUI Bugfix: text in toolbar of shared torrent list and passport pane is displayed incorrectly after switch display resolution
GUI Bugfix: refresh of peer shared torrents list lead to high CPU usage
Core Bugfix: program crash in some condition
Download links:
BitComet v0.88 setup.exe
BitComet v0.88.zip
Download via BitTorrent Network
Postby p2p-sharing-rules » Sun Jun 03, 2007 6:50 pm
BitComet 0.89 Jun 01, 2007
What's New:
GUI Improved: add "Hide this" to context menu of peer shared torrent list, no longer display the selected torrent files
GUI Improved: add "copy title" to context menu of peer shared torrent list, copy the title of selected torrent file to clipboard
GUI Improved: double click downloaded torrent file in peer shared torrent list to view corresponding task in task list
GUI Improved: new icon in my shared torrent file list to show the shared, but not downloaded torrent file
GUI Improved: peer shared torrent list will only refresh once when typing continuously in the filter edit box
GUI Improved: items in peer shared torrent list will keep selected when auto-refresh
GUI Improved: no torrent file will be displayed in shared torrent list in torrent file sha
re disabled in perferences dialog
GUI Improved: the default number to show in the shared torrent list is set to "unlimit"
GUI Improved: new option of socket start interval(ms) in perferences dialog
GUI Bugfix: upload rate displays text error in task list if max upload rate of task is set
GUI Bugfix: operation to torrent will be misplaced after set filter to peer shared torrent list
GUI Bugfix: task number in history task list is not refreshed upon 0 clock at midnight
GUI Bugfix: "Open BC link" in file menu does not work if task summary pane is current active window
Core Bugfix: Share ratio of BT task is always 0 if only uploading without any downloading
Download links:
v0.89 setup.exe
v0.89.zip
.torrent
Postby p2p-sharing-rules » Thu Jun 21, 2007 4:51 am
New BitComet v0.90 Jun 19, 2007
What's New
GUI Improved: add search for eDonkey download source option in BT task properties dialog
GUI Improved: add ED download plugin configuration page in perferences dialog
GUI Improved: display download rate from HTTP/FTP sources and ED sources in BT task summary pane
GUI Improved: shotsnap info for each item in task list and torrent sharelist changed to a clickable icon
GUI Improved: tasks remain selected after sort task list
GUI Improved: new context menu for my shared torrent and peer shared torrent in fav list
GUI Improved: decrease CPU usage for shared torrent list refresh
GUI Improved: new search icon for each item in shared torrent list
GUI Improved: prompt infomation will be displayed when shared torrent list is empty
GUI Improved: add "copy BC link" to context menu of shared torrent list, with hotkey Ctrl+C
GUI Improved: add "clear all" to context menu of peer shared torrent list
GUI Improved: new option in View menu to show search box in toolbar
GUI Improved: shutdown computer after download finish works for HTTP task now
GUI Improved: text in info bar and status bar of review window change to multi-language string
GUI Improved: the last task will be selected when BitComet startup
GUI Improved: minimize to system tray by close button or minimize button can be configured in preferences dialog
GUI Improved: a prompt window will popup if BitComet detected that the TCP half-open limit of windows is too small at startup
GUI Improved: new state of "detecting" for WAN/LAN ip detector in status bar
GUI Improved: HTTP task connection list move to the up of task log
GUI Improved: the auto-start order for queued task keeps the same to display order of sorted task list
GUI Bugfix: preview window fail to refresh when swtich UI language
GUI Bugfix: "pause all active task" in context menu of floating window does not work
GUI Bugfix: program exit confirm when task running do not count up uploading tasks
GUI Bugfix: unable to click task comment, snapshot and voting for items of 10001th and below in shared torrent list
GUI Bugfix: redownload HTTP task will lose task list sort order
Core Improved: BT task support downloading from eDonkey network (ED plugin for BitComet is required)
Core Improved: BT task support uploading to eDonkey network
Core Improved: add eDonkey network listen port to Windows Firewall and UPNP NAT device when program startup
Core Improved: disable NAT Traversal via UDP automatically for WAN IP user, to improve TCP transfer efficiency
Core Bugfix: auto stop running BT task using a invalid condition dismatch to user settings
Core Bugfix: program will lose respond for a while to flush disk cache when downloading huge HTTP/FTP file under Win2003 64bit
Download links:
BitComet v0.90 setup.exe
BitComet v0.90.zip
Last edited by p2p-sharing-rules on Thu Jul 19, 2007 11:00 pm, edited 1 time in total.
Postby p2p-sharing-rules » Thu Jul 19, 2007 10:40 pm
BitComet 0.91 July 19, 2007
What's New:
GUI Improved: double click un-downloaded torrent file in my shared torrent list to start download it
GUI Improved: restore option: add .bc! file extension to unfinished file
GUI Improved: new function in context menu of BT task file list: search ED2K link for selected file
GUI Improved: add real-time sort to task list. enable it from View menu
GUI Improved: new operation in context menu of peer shared torrent list: "add to my share list"
GUI Improved: new status icon for BT task downloading torrent file in task list
GUI Improved: add torrent publish date info to torrent share list
GUI Improved: right click torrent share list header to choose displayed column
GUI Improved: a notifier window will display after add a BC link task
GUI Improved: add file category combo list to torrent share list toolbar
GUI Improved: support multi key words in peer shared torrent list filter, separated by sapce
GUI Improved: torrent file name in torrent share list will be displayed in infotip when mouse hover on it if too long
GUI Improved: specify ED2K link from context menu in file list of BT task, to help ED plugin search ED download resource
GUI Improved: when double click .bc! file, prompt to open the unfinished file using the program associated with the original file without .bc! suffix
GUI Improved: right click toolbar of main window to choose displayed buttons, or using View/Toolbar/Buttons menu
GUI Improved: enable auto adjust column width from View/Tasklist menu
GUI Improved: when HTTP/FTP task connection failed, detail error and retry info will be displayed in connection log
GUI Improved: add HTTP/FTP task error retry interval time option in perferences dialog
GUI Improved: restore allocate disk space before downloading option in perferences dialog
GUI Improved: display upload rate and left time in task list by default
GUI Improved: when available space of save location in BT task properties dialog is not enough, the available space size is displayed in red color
GUI Improved: add copy IP address to context menu of status bar in main window
GUI Improved: display task size, progress and preview button in history task list by default
GUI Bugfix: the order of tasks in queue does not match the order in tasklist when start all task from context menu of floating window
GUI Bugfix: the task number in fav list does not refresh when move task to a new category using context menu of tasklist
GUI Bugfix: the wildcard "(*)" does not work in add HTTP/FTP download group dialog
GUI Bugfix: the HTTP/FTP task in queue failed to stop when double click it in tasklist
GUI Bugfix: the wildcard "(*)" does not work in add HTTP/FTP download group dialog for FTP links
GUI Bugfix: when click cancel button of BT task properties dialog after torrent file downloaded from BC link, the BT task will not be removed
GUI Bugfix: unable to handle non-english character in publisher URL of BT task
Core Improved: support persistent seeding to seed finished torrents in background automatically without starting the task
Core Improved: support uploading rate limit for all persistent seeding, tweak in perferences dialog
Core Improved: support customize file download order for BT task, in BT task properties dialog
Core Improved: support patch TCP half-open limit in Windows Vista
Core Bugfix: program will lose respond for a while to flush disk cache when high-speed downloading HTTP/FTP file from LAN
Core Bugfix: ED plugin will upload invalid data in some situation
Core Bugfix: scheduler failed to resume download after stop tasks for 2 hour or longer
Core Bugfix: unfinished tasks will not auto-start at program startup if BitComet is not closed normally
Download links:
BitComet v0.91 setup.exe
BitComet v0.91.zip
BitComet v0.91 plugin.exe*
Download BitComet v0.91 setup.exe via BitTorrent Network.
* From what I understand the plugin allows you to connect to the eDonkey Network using BitComet.
Battye found this info about it yesterday translated from Chinese? to English using Google.
Plug-in donkey under certain circumstances will slow invalid data
Plug-in order to find the donkey document ED download source
Thanks Battye I wasn't sure what the heck the plugin was for.
Postby p2p-sharing-rules » Sat Sep 15, 2007 10:28 pm
BitComet v0.93 Sept. 10, 2007
What's New
v0.93 Core Improved: improve the stability of persistent seeding
v0.92 Aug. 31, 2007
GUI Improved: task list sorting by task name use pronunciation order
GUI Improved: add "toolkit" menu to download softwares correlated with BitComet
GUI Improved: the global max upload rate in preferences dialog must larger than 10kB/s
GUI Improved: the notice window of free disk space insufficiency will not close until user click
GUI Improved: improved torrent file maker dialog layout, supporting dialog resize
GUI Improved: display file type icons in file list of BT task
GUI Improved: display connection time in peer list of BT task
GUI Improved: HTTP/FTP task support hash check (only support certain files)
GUI Bugfix: bug in sorting my shared torrent list by whether shared
GUI Bugfix: torrent file association error in Windows Vista
GUI Bugfix: downloaded file is not selected correctly when view task save folder in Windows Vista
GUI Bugfix: the right and bottom edge of torrent file maker dialog and BT task properties dialog is not displayed correctly in Windows Vista
GUI Bugfix: RealMediaSplitter.ax registration failed in Windows Vista, result in fail to preview rmvb file
GUI Bugfix: available space size in BT task properties dialog displayed in red color mistakenly, not considering task downloaded size
GUI Bugfix: the option of replace wildcard "(*)" to letters does not work in add HTTP download group dialog
GUI Bugfix: fail to set torrent file create date when add it to my shared torrent list from new BT task dialog
Core Improved: add "preview download mode" in BT task context menu, supporting download pieces in sequence
Core Improved: eMule plugin support sending crash report
Core Bugfix: new BT task will stop downloading due to nonexistent disk error in some situation
Core Bugfix: default TCP half open limit in Windows Vista is displayed as 0. it's 10 actually
Download links
BitComet v0.93 setup.exe
BitComet v0.93.zip
BitComet v0.92 setup.exe
BitComet v0.92 plugin.exe
BitComet v0.92.zip
PreviousNext
Return to P2P File Sharing
