[WinMX] udp problem
yeah im having problems with logging onto winmx (v3.31) to a prmary connection when i have adsl 512/256 kb/s router is there any way of fixing this problem, i am the current computer administrator and is able of changing settings
help much appreciated
thanx
REAL MEN BURN "RUBBER"
If you are on a router you will need to set up port forwarding to allow UDP traffic. Check the user manual for your router on how to do this. If you are using a firewall you will have to allow it also usually by making a rule.
- Boozybaz
- Alcoholic
standard ports for winmx are as follows
6699 TCP
6257 UDP
if they dont work a good trick is to just add a 1 to the start of both
16699 TCP
16257 UDP
try them... but you must make sure that the ports in winmx match the ports in your router.
good luck
6699 TCP
6257 UDP
16699 TCP
16257 UDP
good luck
