kingmacro.net.
Latest News
WCS 1.8b9 has been released. This adds a couple of little things to the 1.8 series.
Changes since b8 are:
+ Added #c0# for "previous colour" (may be used multiple times)
+ Added #c1,2,3# syntax for selected random colours
+ Added /hide command to hide from the user list (h access required)
+ added RestrictColours=0/1 option to the config, this makes it only accept "valid" colour codes
+ Added IPSend Support (for compatible clients to get IP Addresses when logged in)
Explainations:
#c0# will return to a previous colour, for example if you use #c4#Something#c5#Something Else#c0#Something, then the first and last Something will both be colour 4 (as the previous colour is 4). You can use this multiple times (to go back several colours). Most useful for Replace=, but i'm sure you'll find other uses.
#c1,2# will randomly select one of the listed colours, that example will randomly select between colour 1 or 2. #c7,8,56# will randomly select between 7 8 or 56.
RestrictColours=1 in the config will make it block all colour codes between 9 and 52, and above 76 (except 253), this eliminates the mostly blank colour codes.
