Ultimate Quiz Mod
I haven't added a feature to delete yet :oops:
To edit, simply click it (the name of the category or subcategory)
:D
hassack
I have this error ... any idea ???
Cannot update view counter
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 3
UPDATE phpbb_quiz SET quiz_views = quiz_views + 1 WHERE quiz_id =
Line : 112
File : quizzer.php
Great .. Great Mod ... realy , are there any way to don't make always the first question always the right question ???
thx .. great job ..
EDIT :
I can solved , changing ..
$vchundred = "UPDATE " . QUIZ_TABLE . "
	WHERE quiz_name = ' . $page . ;
to
	WHERE quiz_name = '" . $qnm . "'";
Is this OK ??? , work now , but i know if it's ok :)
Plus , I find a mising var in lang_admin.php ----> $lang['guest_cant']
Thx again
EDIT 2 : I solved the problems with always the right anwser is the first choice
i need to add ...
srand((double)microtime()*1000000);
at the begining of viewquestion.php to initializate random uses with suffle() funtion , i guest my php version in my hosting company is older than v4.2
Thx
It's been a while since I've updated this post, basically I am not adding more features until the second major release.
So far I have added the following:
  • Current Features
    Index Page
  • Link to quizzes
  • Categories
  • Statistics
  • Page Views For Completed Quizzes (Not on a per question basis)
  • Author
  • Link to Random Quizzes
    Playing The Quiz
  • 4 Multiple Choice Answers
  • Shuffled
  • Layout (by Xusqui)
  • Incorrect / Correct answers after playing
  • Indepth statistics about how you went
  • DHTML Statistics Drop Down Box
  • Pagination
  • Cash Rewards
  • New Redirection Engine
  • Image Support
  • Time Limit Feature
  • Admin's can delete or edit quizzes
  • Optional feature so the Quiz doubles as a survey
  • Ability to play a quiz picked at random from the database
    Adding Quizzes
  • Questions
  • Fakes / Answer
  • Quiz Name
  • Image Support
    Admin Panel
  • Quiz Configuration
  • Category Admin
  • Configure cash / points settings
  • Verify Quizzes
    Statistics
  • Modules
  • TPL Files
  • Drop down statistics box when viewing quiz
  • Optional surveys
Am I missing anything?
Please tell me so I can add it to the list :)
Locked
