PetitionMX
PetitionMX
Postby battye » Mon Aug 22, 2005 6:24 am
This is a neat little program I made last night, it is a "database-less" system which can be used to create online petitions.
If you have a website which uses PHP (nothing else required!) then all you need to do is upload one PHP file, and one TXT file (What the data is stored in) and create your petition topic, and you're away! :)
So, if you are aware of anyone wishing to make a petition online, or if you wish to make one yourself, look no further than: PetitionMX
http://www.cricketmx.com/petitionmx/
Note: This is not the big secret from Don't Miss Out!
Postby hockeyjock686 » Mon Aug 22, 2005 3:07 pm
haha great idea...now we can get whatever we want
hockeyjock686
Music Man
Music Man
Postby moongirl » Tue Aug 23, 2005 3:11 am
Battye, well done!!
So, what is to be the subject of our first petition? :wink:
....................................ImageImage ImageImage
Nanananana na.. I get to celebrate Christmas with a bunch of friends!! ;)
Click To Play Online-Scrabble
~~~In the year 2040...I'll have 100,000 posts!!~~~
Postby hockeyjock686 » Wed Aug 24, 2005 4:31 am
lets get...dream theatre to play in our houses
hockeyjock686
Music Man
Music Man
Postby moongirl » Thu Aug 25, 2005 1:29 am
Well, only if they will answer questions about Nicholas and Victoria :wink:
Postby hockeyjock686 » Thu Aug 25, 2005 6:40 am
seriously, if they don't i'll kill them
hockeyjock686
Music Man
Music Man
Postby nesman » Thu Nov 10, 2005 8:44 am
I'm just posting here to help me find this again later when I'm searchnig for guestbook or guest book. I hope I remember that it's actually called PetitionMX, as that'll be a lot easier to dig for in the results. :)
Btw, thanks, Battye.
Postby nesman » Wed Nov 16, 2005 10:51 am
I've been messing with PetitionMX ( http://nesman.afraid.org/pmx ), and I found some entries in my apache error logs. I don't know if it's something in the script, or if I've messed up my apache/php.
[Wed Nov 16 04:30:35 2005] [error] PHP Notice:  Undefined index:  mode in /var/www/htdocs/pmx/petition.php on line 2
[Wed Nov 16 04:30:35 2005] [error] PHP Notice:  Undefined index:  mode in /var/www/htdocs/pmx/petition.php on line 38
[Wed Nov 16 04:30:35 2005] [error] PHP Notice:  Undefined index:  mode in /var/www/htdocs/pmx/petition.php on line 66
[Wed Nov 16 04:31:10 2005] [error] PHP Notice:  Undefined index:  action in /var/www/htdocs/pmx/petition.php on line 70
The first 3 are from launching the petition.php, and the last one comes when you add a sig.
Any ideas?
Most likely it's something on my side, as it took me a few days to figure out how to enable php in the first place. I could run php from a command prompt, but if I hit it from the web, apache treated it like text. internal.html was the output of running the script from the prompt.
Postby battye » Wed Nov 16, 2005 12:20 pm
Firstly, is it even working (PetitionMX)?
What version of PHP do you run?
Postby nesman » Wed Nov 16, 2005 2:09 pm
It is running nicely (see link from above). That's the funny part. From the updater's perspective, everything is perfect.
As far as I can tell, I'm running PHP version 4.3.10 (it came with Slackware)
I've moved a copy of phpinfo.php into the pmx directory. I also put a copy of petition.php as source.txt to make it easier for me to look it over.
I don't know enough php yet to know if 'mode' and 'action' are being used as variables or if they are functions/commands in php.
And, like I said, I'm so new with apache that I really don't know if I've got anything set up right. You wouldn't believe the troubles I ran into trying to get a cgi upload working in my /upload dir. You can check it out by telling it yesIdo and letmein when it prompts. Putting that together taught me about .htaccess files and why ftp ascii mode is important when moving text-cgi files. :)
Edit: There's now a log.php in the pmx folder. I got tired of typing the command to display the error log, so I found a php script that'll display it for me. I tried to make one up, but I wasn't quite doing it correctly.
Postby battye » Wed Nov 16, 2005 2:43 pm
Looks like it doesn't like $HTTP_GET_VARS
Both mode and action are part of the $HTTP_GET_VARS array.
I'll explain it a bit. Look in your browser, and you will see: /viewtopic.php?p=53374#53374 (if you click the last post link that is :wink: Otherwise it will be t=xxxx).
$HTTP_GET_VARS['p'] = 53374#53374 :)
So PHP is having problems handing both $HTTP_GET_VARS['mode'] and $HTTP_GET_VARS['action'] it would seem.
The reason, I don't quite know :lol:
As far is I can see, your installation works perfectly though, which makes it even stranger.
Postby nesman » Wed Nov 16, 2005 11:44 pm
I'll try it on another server and see what happens. Then I'll try to compare settings and see what happens.
Postby nesman » Thu Nov 17, 2005 7:36 am
I've been messing with it on a server at work, and I didn't get the errors at all. Then I remembered helping a customer adjust their error logging and display for some php, and found some code to put in a .htaccess file. When I turn the error logging all the way up, it shows them. I guess I should find where my error logging is configured at home and tweak the level a bit.
Maybe you can add full logging or even notice (1024) to yours for a bit to see if you get the same? At first, when the script worked, and only I got the error, I figured this problem rated about a 0.4 out of 10. Now that it just looks like a 'notice' and not an 'error' I think It's moved to a 0.04 out of 10. :)
This is where I found the info. http://webhelp.ucs.ed.ac.uk/services/php/
Postby battye » Thu Nov 17, 2005 9:18 am
I doubt it makes a difference, but you said you used 4.3.10. The latest is 4.3.11 (which is what I use).
Postby nesman » Thu Nov 17, 2005 1:03 pm
Yeah. I don't think it matters either. I was using 4.3.11 at work. I think it only depends on the level of logging. I'm going to mess with it some more later to make sure, but I'm starting to think that it's about as dangerous as not being wc3 compliant. :)
Return to Updates
