CricketMX.com has already been updated to 2.0.13.
phpBB 2.0.12 to phpBB 2.0.13 Code Changes
As mentioned in this topic at phpBB.com
These are the Changes from phpBB 2.0.12 to phpBB 2.0.13 summed up into a little Mod. This might be very helpful if you want to update your Board and have installed a bunch of Mods. Then it's normally easier to apply the Code Changes than to install all Mods again.
When you find a 'AFTER, ADD'-Statement, the Code have to be added after the last line quoted in the 'FIND'-Statement.
When you find a 'BEFORE, ADD'-Statement, the Code have to be added before the first line quoted in the 'FIND'-Statement.
When you find a 'REPLACE WITH'-Statement, the Code quoted in the 'FIND'-Statement have to be replaced completely with the quoted Code in the 'REPLACE WITH'-Statement.
When you find a 'DELETE'-Statement, the Code have to be deleted.
After you have finished this tutorial, you have to upload the update_to_latest.php file, execute it and then delete it from your webspace.
Ok, lets start:
- includes/sessions.php
if( $sessiondata['autologinid'] == $auto_login_key )
if( $sessiondata['autologinid'] === $auto_login_key )
- viewtopic.php
$message = str_replace('\"', '"', substr(preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "preg_replace('#\b(" . $highlight_match . ")\b#i', '<span style=\"color:#" . $theme['fontcolor3'] . "\"><b>\\\\1</b></span>', '\\0')", '>' . $message . '<'), 1, -1));
$message = str_replace('\"', '"', substr(@preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "@preg_replace('#\b(" . $highlight_match . ")\b#i', '<span style=\"color:#" . $theme['fontcolor3'] . "\"><b>\\\\1</b></span>', '\\0')", '>' . $message . '<'), 1, -1));
Once done, run the update_to_latest.php file which can be found in the Changed Files package, it can be obtained from here.
